[Geoserver-users] Java Service Wrapper and gdaljni
You will not be able to access a certain number of formats.
For reference see:
http://geoserver.org/display/GEOSDOC/ImageIO-ext+GDAL+extensions
http://docs.codehaus.org/display/GEOTOOLS/ImageIO-EXT+GDAL
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Apr 22, 2009 at 1:03 AM, Patel, Ronak Avinash (US SSA)
<ronak.patel@anonymised.com> wrote:
So will I lose any functionality as a result of the gdal native libraries not being found? I remember reading that JPEG2000, NITF and a few other formats are only supported through GDAL.
Is this true?
If I will lose functionality, I would like to yse the gdal based extension.
I will look for instructions on how to install those with the service wrapper.
Ronak
-----Original Message-----
From: simboss1@anonymised.com [mailto:simboss1@anonymised.com] On Behalf Of Simone Giannecchini
Sent: Tuesday, April 21, 2009 4:01 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] Java Service Wrapper and gdaljni
Ciao Ronak,
unless you are willing to use the gdal based extension you are free to
ignore that message.
Notice, however, that it is simple a warning to tell people that gdal
native extensions won't be installed.
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
On Wed, Apr 22, 2009 at 12:45 AM, Patel, Ronak Avinash (US SSA)
I'm trying to use the Java Service Wrapper to start Geoserver as a
Windows Service.
I installed the Java Service Wrapper as per the instructions at:
http://geoserver.org/display/GEOSDOC/Windows+Service+Wrapper
However, I see that the java.library.path variable gets overwritten by
the wrapper.conf from the service wrapper.
This results in Geoserver spitting out errors:
jvm 1 | WARNING: Native library load
failed.java.lang.UnsatisfiedLinkError: n
o gdaljni in java.library.path
What do I have to do to get rid of these errors? Should I use the
imageio-ext libraries on Windows? I don't really see any dlls in there
when I expanded it...
Anyone else experiencing this problem?
Ronak Patel
Stay on top of everything new and different, both inside and
around Java (TM) technology - register by April 22, and save
$200 on the JavaOne (SM) conference, June 2-5, 2009, San Francisco.
300 plus technical and hands-on sessions. Register today.
Use priority code J9JMT32. http://p.sf.net/sfu/p
Geoserver-users mailing list
