[Geoserver-users] KML Reflector remote SLD problems
Hello all!
I should first start by saying I am not sure what I am trying to do is possible. Although geoserver is pretty sweet and haven’t found much that I could not do :slight_smile:
I am trying to use the KML reflector and attach a remote sld url in the request. The sld in question has an ExternalGraphic, but I have also tried with just a general color style and I get the same exception. The sld that is generated looks like this:
cite:mylayer
My Layer image/png 64
And the exception I get is:
15 Jul 15:50:10 ERROR [geoserver.ows] -
java.lang.NullPointerException
at org.geoserver.kml.decorator.PlacemarkStyleDecoratorFactory$PlacemarkStyleDecorator.setLiveIconStyle(PlacemarkStyleDecoratorFactory.java:259)
at org.geoserver.kml.decorator.PlacemarkStyleDecoratorFactory$PlacemarkStyleDecorator.setIconStyle(PlacemarkStyleDecoratorFactory.java:204)
at org.geoserver.kml.decorator.PlacemarkStyleDecoratorFactory$PlacemarkStyleDecorator.decorate(PlacemarkStyleDecoratorFactory.java:102)
at org.geoserver.kml.sequence.FeatureSequenceFactory$FeatureGenerator.next(FeatureSequenceFactory.java:121)
at org.geoserver.kml.sequence.FeatureSequenceFactory$FeatureGenerator.next(FeatureSequenceFactory.java:80)
at org.geoserver.kml.sequence.SequenceList$GeneratorIterator.(SequenceList.java:29)
at org.geoserver.kml.sequence.SequenceList.iterator(SequenceList.java:63)
A couple things:
  • The SLD works great when used in a simple WMS request with format=image/png
  • I was trying a more complex OnlineResource that had CQL, but moved to a simple google icon that I know is available
So the question is, can I use an SLD to generate icons with the KML reflector? Can the sld come from a remote server? If yes, any idea on what I might be doing wrong?
Shaun
Hi Shaun,
out of the box, and from a general point of view, I don’t believe this is feasible, because GeoServer will try to link
back to itself either to generate the actual KML only when you are zoomed in enough, using a static image when
you are too far away from the ground, and when it does, it will link back to itself for generality sake, in order to
render all types of graphics (not just ones that are already online, and even for those, it’s hard to tell if the
graphic is available only to the server, because it’s referencing some other server in DMZ, or also to the client).
For the restricted case where you are trying to get the KML features right away (dump mode) and you are telling
GeoServer that icons are available also to the client (under your responsibility) it could be made to work… but only
with some code changes, and adding a new request parameter to enable/disable “live icons” (that is, backlinks
to GeoServer that will make GS generate PNGs of the icons based on a local style reference).
If you are interested in such improvement read here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
On Sat, Jul 16, 2016 at 3:51 AM, Shaun Taggart <forumshaun8@anonymised.com> wrote:
Hello all!
cite:mylayer
A couple things:
Shaun
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
Sorry for the duplicate email, forgot to reply all :confused:
Thanks so much for the response. I am still a bit confused. I am using the following SLD for KML output as a simple test:
<StyledLayerDescriptor xmlns="[http://www.opengis.net/sld](http://www.opengis.net/sld)" xmlns:ogc="[http://www.opengis.net/ogc](http://www.opengis.net/ogc)" xmlns:xlink="[http://www.w3.org/1999/xlink](http://www.w3.org/1999/xlink)" xmlns:xsi="[http://www.w3.org/2001/XMLSchema-instance](http://www.w3.org/2001/XMLSchema-instance)" version="1.0.0" xsi:schemaLocation="[http://www.opengis.net/sld](http://www.opengis.net/sld) StyledLayerDescriptor.xsd">
<NamedLayer>
    <Name>cite:mylayer</Name>
    <UserStyle>
        <Title>My Layer</Title>
        <FeatureTypeStyle>
            <Rule>
                <PointSymbolizer>
                    <Graphic>
                        <Mark>
                            <Fill>
                                <CssParameter name="fill">#ff0000</CssParameter>
                            </Fill>
                        </Mark>
                    </Graphic>
                </PointSymbolizer>
            </Rule>
        </FeatureTypeStyle>
    </UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
This SLD comes the KML styling documentation here: [http://docs.geoserver.org/2.3.2/user/googleearth/kmlstyling.html#kml-styling-sld-structure](http://docs.geoserver.org/2.3.2/user/googleearth/kmlstyling.html#kml-styling-sld-structure)
Shouldn't that work?
That SLD throws the same exception:
	at org.geoserver.kml.sequence.SequenceList$GeneratorIterator.<init>(SequenceList.java:29)
Sorry if I am missing something obvious, and thanks again for the quick response.
On Sun, Jul 17, 2016 at 6:25 AM, Andrea Aime <andrea.aime@anonymised.com..> wrote:
Hi Shaun,
Hello all!
cite:mylayer
A couple things:
Shaun
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Jul 18, 2016 at 5:45 PM, Shaun Taggart <forumshaun8@anonymised.com>
wrote:
This SLD comes the KML styling documentation here: http://docs.geoserver.org/2.3.2/user/googleearth/kmlstyling.html#kml-styling-sld-structure
Not if you are sending the SLD along with the request or referring to a
remote one, it's going to work only if the style is configured in GeoServer
as a local style
and you are referring to it by name instead.
The NPE is happening because the code tries to find the style in the local
configured styles, and cannot find it
(since your style is remote).
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
