Hi List,
I’m getting some weird labelling behaviour (using GS 2.5.1).
The entire large street is unlabelled. It’s supposed to have two separate labels from two attributes of the same feature coming from one rule with two TextSymbolisers. One places a road number (Like the “A445” at the top) and the other places the road name (like the “castle hill” in the bottom left).
But for some reason neither is appearing here. If I pan around a bit, sometimes one of them shows and sometimes the other one but rarely both. Zooming in/out has similar effects.
This is what the line feature looks like (four components):
I’m using these vendor options for both labels:
<se:VendorOption name=“group”>yes</se:VendorOption>
<se:VendorOption name=“followLine”>true</se:VendorOption>
I’ve tried adding a “repeat” option, but that didn’t seem to have the desired effect.
It’s no less random via a TMS (4*4 meta tiling).
Doe anyone have any suggestions? I know labelling can be something of a dark art, but this one has me stumped.
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
