[Geoserver-users] Labels disappear when extended over several tiles
Hello,
I’m using GeoServer 2.3.1 with Oracle database, my problem is that my labels disappear when the text overlaps two tiles.
Do you know a solution that allows to truncate these texts at tiles border in order to make each text part on separate tiles.
Thanks for your help.
Best regards,
Kamardine
On Thu, Jul 18, 2013 at 10:52 AM, KAMARDINE YOUSSOUFA <
kamardine.youssoufa@anonymised.com> wrote:
Hello,
I'm using GeoServer 2.3.1 with Oracle database, my problem is that my
We would need a new vendor option in the text symbolizer to allow for
truncated label.
It's not there, but if you can develop in Java and are interested, I can
point you at the classes that would need to be modified
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Kamardine,
These labels disappearing are a typical result of tiling. The main approach to overcome this is to request larger images that would provide enough space for the offending labels to be drawn. In a next step, these meta tiles are sliced into smaller image tiles. GeoWebCache that comes with GeoServer nowadays does just that.
Maybe I am just stating the obvious here, so Andrea’s solution might still be valid and meta tiling is of no use in your case. Just thought I’d throw in this angle as well.
Best,
Edward
Date: Thu, 18 Jul 2013 11:21:40 +0200
To: kamardine.youssoufa@anonymised.com
CC: geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] Labels disappear when extended over several tiles
On Thu, Jul 18, 2013 at 10:52 AM, KAMARDINE YOUSSOUFA <kamardine.youssoufa@anonymised.com> wrote:
Hello,
We would need a new vendor option in the text symbolizer to allow for truncated label.
It’s not there, but if you can develop in Java and are interested, I can point you at the classes that would need to be modified
Ing. Andrea Aime
@geowolf
Technical Lead
------------------------------------------------------------------------------ See everything from the browser to the database with AppDynamics Get end-to-end visibility with application monitoring from AppDynamics Isolate bottlenecks and diagnose root cause in seconds. Start your free trial of AppDynamics Pro today! http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
_______________________________________________ Geoserver-users mailing list Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
