[Geoserver-users] Large ECW files
I have a number of large ECW files (+40MB) that I would like to serve out as a WMS.
Can geoserver handle this and if so how?
Jerry
Size isn't an issue for GeoServer, it often serves of files that are
many gigabytes in size. But as for ecw files, it doesn't serve them
(at least I don't think so).
On 4/16/07, Jerry O'Sullivan <jeremiahosullivan@anonymised.com> wrote:
a WMS.
Jerry
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
Brent Owens
Brent Owens
Jerry O'Sullivan ha scritto:
Geoserver cannot read ECW at the moment. Your best bet is to
turn them into JPEG compressed Geotiff files, with tiles and overviews,
using gdal_translate.
This may be of use to you Brent (Although the pyramiding doesn't work)
http://docs.codehaus.org/display/GEOSDOC/Load+NASA+Blue+Marble+Data
It describes how to turn the ecw's into geotiffs
-----Original Message-----
From: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net] On Behalf Of Brent
Owens
Sent: Monday, April 16, 2007 5:55 PM
Subject: [Geoserver-users] Fwd: Large ECW files
as
a WMS.
Jerry
Brent Owens
Brent Owens
Thanks Andrea
The problem I was coming up against was that I was trying to merge my ecws into a single tiff using gdal_merge and I was hitting a 4mb limit.
When I used the gdal_tranlsate to translate my 11MB ecw to tiff it went up to 1GB!, As I have a lot of these ecw files I will have to think about another way of serving them up.
I will try your suggestion of JPEG compressed Geotiff files tomorrow, do you have any examples of the syntax for this?
Thanks
Jerry
On 16/04/07, Andrea Aime <aaime@anonymised.com> wrote:
Jerry O’Sullivan ha scritto:
out as a WMS.
Thanks Andrea
Hem, no. Have a look at both the gdal_translate help page at www.gdal.org and at the geotiff format help page on the same site to
look at the creation options.
Then add the overviews with gdaladdo.
The limit on the size of TIFFs is 4GB, so you should be fine. If you
get above the 4GB limit, you can create several TIFFs and just load
them as separate layers in GeoServer. Also, GeoServer can handle 1GB
tiffs just fine, you might have to split them up into a pyramid, but
it can still serve them up quite well. Check out this tutorial on how
to serve up large rasters:
cheers,
Thanks for the quick reply Brent
Any ideas?
Thanks
Jerry
> > Hi,
out as
> > a WMS.
> > Thanks,
> > Jerry
> > _______________________________________________
> > Geoserver-users@lists.sourceforge.net
> Brent Owens
Brent Owens
Hey Andrea,
I converted the ecw’s to tiff with the tiled and JPEG options but the image gets corrupted :(. Have you any ideas on this. At the moment I am going with Tiff LZW which is a larger file but at least correct.
Forgive my ignorance but what are overviews and why should I have them?
Thanks
Jerry
Thanks Andrea
