[Geoserver-users] Layer level security
Hello all,
I’m having some difficulties to implemente layer-level security in geoserver 2.0 snapshot.
I have 2 different roles: ROLE_ADMINISTRATOR and Test.
If i configure the layers.properties file like the follwoing:
..r=ROLE_ADMINISTRATOR
..w=ROLE_ADMINISTRATOR
repivet.*.r=Test
mode=MIXED
When i try to load any wms into qgis or udig, none of the roles is detecting any layer in the WMS GetCapabilities request.
Am i doing something wrong here or is this a known problem??
Thanks in advance.
Best regards,
Hugo
Hugo Martins
FMV-UTL
CIISA-Epidemiologia e Saúde Pública Veterinária
Av. da Universidade Técnica
1300-477 Lisboa
N 38°42’49.54", W 9°11’43.42"
Try setting the mode to CHALLENGE instead. MIXED mode causes GeoServer to filter the Capabilities document without giving the client any clue that there might be secured layers, CHALLENGE mode will list them all so that the client at least knows they exist so it can try requesting them.
David Winslow
OpenGeo - http://opengeo.org/
On Fri, Oct 8, 2010 at 11:47 AM, Hugo <hfpmartins@anonymised.com> wrote:
Hello all,
repivet.*.r=Test
mode=MIXED
Thanks in advance.
Best regards,
Hugo
Hugo Martins
FMV-UTL
1300-477 Lisboa
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
Geoserver-users mailing list
Hi David,
Thanks very much for your answer. It works with the Challenge mode. However, is there any to only display the available layers for a specific role??? I’ve tried hide mode, but however, using this approach, no layer is displayed in any type of role.
Best regards,
Hugo
On Fri, Oct 8, 2010 at 5:10 PM, David Winslow <dwinslow@anonymised.com> wrote:
David Winslow
Hello all,
repivet.*.r=Test
mode=MIXED
Thanks in advance.
Best regards,
Hugo
Hugo Martins
FMV-UTL
1300-477 Lisboa
Hugo Martins
FMV-UTL
1300-477 Lisboa
