I’ve installed GeoServer via OpenGeoSuite and it was working beautifully with all my rasters and vectors from PostGIS database viewable in GeoExplorer and Layer Preview. I am running off of an AWS EC2 Windows Server 2012 instance with PostgreSQL/PostGIS and IIS configuration.
I’m not sure when it happened, but when I click on the “OpenLayers” for any of my layers on the Layer Preview section, I get the error
HTTP ERROR 404
Problem accessing /opengeo/wms. Reason:
Not Found
GeoXplorer no longer pulls up my WMS/WFS and just serves broken tiles. It does, however, still loads a published map before things had stopped connecting.
I hovered over the link and found it to read http://localhost:8080/folderexample/wms when I think it should be similar to
http://localhost:8080/geoserver/folderexample/wms
I tested it out by clicking on a random layer’s “OpenLayers” link, and manually changed it to add the ‘geoserver’ section and it served a blank window.
Is there a way to alter the path? I thought it was under Workspace > Namespace URI but wasn’t successful. Any ideas why its not being called up correctly? Thanks!
View this message in context: Layer Preview and GeoExplorer render error; wrong pathname?
