[Geoserver-users] Layer Preview Error
GeoServer User
When I perform a “Layer Preview” check on newly added Shapefile and then click on a feature to check for attributes I get the following error message
Any ideas what I have done.
ava.lang.IllegalArgumentException: Can’t find neither a FeatureType nor a CoverageInfo named http://www.opengeospatial.net/cite:af_provincial_bndry_poly Can’t find neither a FeatureType nor a CoverageInfo named http://www.opengeospatial.net/cite:af_provincial_bndry_poly
Jeff
Hi Jeff. I think I encountered that double negative a few months ago. I feel like that was an error related to the default workspace that was fixed by 2.0.1. What version are you using?
Mike Pumphrey
OpenGeo - http://opengeo.org
On 3/15/2010 10:31 PM, Jeff Reichman wrote:
GeoServer User
ava.lang.IllegalArgumentException: Can't find neither a FeatureType nor
http://www.opengeospatial.net/cite:af_provincial_bndry_poly Can't find
Jeff
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
Geoserver-users mailing list
Jeff Reichman ha scritto:
GeoServer User
As Mike suggested, please try out 2.0.1 if you're not using
it already.
If you are already using it, can you locate geoserver.log in
your data directory and provide us with the full stack trace
associated to that user interface error?
Andrea Aime
GeoServer User
it already.
I've attached an update to this to ticket GEOS-3337
(http://jira.codehaus.org/secure/ManageAttachments.jspa?id=95896).
I can show the bug in 2.0.1 and today's nightly.
Please ask if you need more info.
Ian
Ian Turton
Further investigation indicates that the problem may be related to how
you load the shapefile. In the first case I loaded it as a shapefile,
trying again now by loading it as a directory of shapefiles works just
fine.
So compare http://webmapping.mgis.psu.edu/geoserver/www/denslow/NCFlorasDemo.html
and http://webmapping.mgis.psu.edu/geoserver/www/denslow/NCFlorasDemo3.html
The only difference is how I loaded the shapefile.
Ian
