[Geoserver-users] LDAP Authentication
Hello. I’m having a bit of trouble with LDAP authentication and wondering if there’s a known issue.
I’m running 2.2-beta2 on a Ubuntu 11.10 system. GeoServer seems to be functioning quite well.
However, if I attempt to use LDAP authentication, things don’t go so well. Following the instructions here: http://docs.geoserver.org/latest/en/user/security/tutorials/ldap/index.html, all initially goes well. Test Connection indicates “Connection Successful.” However, I move on to the next section (“Test a LDAP login”) but when attempting to log in as “bob”, GeoServer only hangs indefinitely.
I’ve tried the same with my own LDAP server instead of acme-ldap and the same thing happens.
Has anyone else seen something similar?
With thanks,
Emilio
Hi Emilio,
I think actually just fixed this last last night. If you grab the latest nightly build you should hopefully see the issue go away.
-Justin
On Thu, May 31, 2012 at 2:12 PM, Emilio Millán <emilio.millan@anonymised.com4919…> wrote:
With thanks,
Emilio
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Thank you, Justin! I can confirm that it is fixed in the nightly build.
To recap: LDAP authentication appears to work great in beta1 and in the latest nightlies, but was broken at the time of beta2.
All the best,
Emilio
On Fri, Jun 1, 2012 at 10:00 AM, Justin Deoliveira <jdeolive@anonymised.com…1671…> wrote:
Hi Emilio,
-Justin
With thanks,
Emilio
Justin Deoliveira
