I only started working with SLD recently, and a challenge emerged. Is it possible to create leader lines connecting labels with features of point type shapefile? I still have not found any examples, tips etc. SLD specification and GeoServer docs (labeling reference) does not contain any hints either.
Thanks in advance for answers.
On Tue, Mar 1, 2016 at 11:12 AM, Piotr Kosz <piotr.kosz.91@anonymised.com> wrote:
hints either.
Standard SLD does not have a notion of leader line, and GeoServer
extensions to SLD are not covering it
either.
It would be a welcomed addition though, if you are interested in pushing
this forward we have a guide you here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
One option would be to create a label layer using the Easy Custom Labeling plugin in QGIS which generates a new layer with the labels, points, leaders etc in it which you could style using SLD. QGIS might even export the style the plugin creates as SLD for you.
Ian
On 1 March 2016 at 10:26, Andrea Aime <andrea.aime@anonymised.com> wrote:
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Standard SLD does not have a notion of leader line, and GeoServer extensions to SLD are not covering it
either.
It would be a welcomed addition though, if you are interested in pushing this forward we have a guide you here:
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Although one thing to bear in mind - more complex SLD’s created with QGIS often don’t work in GeoServer without manual tweaking. Certainly worth trying though.
Jonathan
---- On Tue, 01 Mar 2016 10:36:36 +0000 Ian Turton ijturton@anonymised.com wrote ----
Ian
either.
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServerCheers
Andrea–
http://goo.gl/it488V for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
phone: +39 0584 962313fax: +39 0584 1660272
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_itAVVERTENZE AI SENSI DEL D.Lgs. 196/2003
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
Ian Turton
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140_______________________________________________
I created nice leader lines with Easy Custom Labeling plugin, but style has not been exported to SLD properly (it is known that QGIS has problem with this format). As is known, conversion of QML to SLD is impossible, and Geoserver does not support QML. I thought about extending SLD with (for example) piece of GML or something… But I feel it is not a viable way. Such SLD might not work at all, and defining each leader line for large point type shapefile will enlarge SLD file excessively.
2016-03-01 11:12 GMT+01:00 Piotr Kosz <piotr.kosz.91@anonymised.com>:
There shouldn’t be any need to add GML to the SLD file as the leader lines are stored in the layer, so a simple line style should do it. Can you put the data layer somewhere I can see it and I might be able to play with it over the weekend
Ian
Ian Turton
