[Geoserver-users] legend not showing in Geoserver
Dear Geoserver Support
Hope this email finds you well.
I would like to report an issue I am facing with Geoserver legend not showing.
For the last few weeks Geoserver is not being able to draw a legend (before that was working fine).
I tried to go under “styles” sections and then click on preview, and I got the error message below:
Would like to ask if you have any suggestion that might solve this issue?
Also please let me know if you need any additional information?
Many thanks,
Daniel
we need to see the whole of the error message as text (not an image) and the SLD you are using for the style before there is any chance of us being able to help
Ian
Ian Turton
Hi Ian,
Thanks for the quick response.
Please see the txt file attached with the errors.
Many thanks,
Daniel
geoserver_error.txt (15.1 KB)
Sent: 29 April 2022 16:55
To: Daniel Campeao Daniel.Campeao@anonymised.com
Subject: Re: [Geoserver-users] legend not showing in Geoserver
CAUTION: This email originated from outside of KALIBRATE. Do not click links or open attachments unless you recognise the sender and know the content is safe!
Ian
On Fri, 29 Apr 2022 at 14:21, Daniel Campeao via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Many thanks,
Daniel
This message (including any attachments) is confidential. It may contain sensitive and proprietary or legally privileged information. If you are not the intended recipient, please delete it or any copies of it immediately and notify the sender. You must not use, copy, or distribute any part of this message if you are not the intended recipient. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorized to make such a statement.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ian Turton
sld:NamedLayer
sld:NameDefault Styler</sld:Name>
sld:UserStyle
sld:AbstractDemand Household count with categories standarized with Natural Break Jenk</sld:Abstract>
sld:FeatureTypeStyle
sld:Namename</sld:Name>
sld:Rule
sld:Title0 - 367</sld:Title>
ogc:Filter
ogc:Or
ogc:PropertyIsEqualTo
ogc:PropertyNameCategory_House</ogc:PropertyName>
ogc:Literal1</ogc:Literal>
</ogc:PropertyIsEqualTo>
ogc:Literal2</ogc:Literal>
ogc:Literal3</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:PolygonSymbolizer
sld:Fill
<sld:CssParameter name=“fill”>#ffffcc</sld:CssParameter>
<sld:CssParameter name=“fill-opacity”>0.65</sld:CssParameter>
</sld:Fill>
sld:Stroke
<sld:CssParameter name=“stroke”>#4C8067</sld:CssParameter>
<sld:CssParameter name=“stroke-linejoin”>bevel</sld:CssParameter>
<sld:CssParameter name=“stroke-opacity”>0.74</sld:CssParameter>
<sld:CssParameter name=“stroke-width”>
<ogc:Function name=“Categorize”>
<ogc:Function name=“env”>
ogc:Literalwms_scale_denominator</ogc:Literal>
</ogc:Function>
ogc:Literal150000</ogc:Literal>
ogc:Literal1.5</ogc:Literal>
ogc:Literal400000</ogc:Literal>
ogc:Literal700000</ogc:Literal>
ogc:Literal0.7</ogc:Literal>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:PolygonSymbolizer>
</sld:Rule>
sld:Rule
sld:Title368 - 501</sld:Title>
ogc:Filter
ogc:Or
ogc:Literal4</ogc:Literal>
ogc:Literal5</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:Fill
<sld:CssParameter name=“fill”>#d7efaa</sld:CssParameter>
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
sld:Title502 - 612</sld:Title>
ogc:Filter
ogc:Or
ogc:Literal6</ogc:Literal>
ogc:Literal7</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:Fill
<sld:CssParameter name=“fill”>#a9dc8e</sld:CssParameter>
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
sld:Title613 - 738</sld:Title>
ogc:Filter
ogc:Or
ogc:Literal8</ogc:Literal>
ogc:Literal9</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:Fill
<sld:CssParameter name=“fill”>#78c679</sld:CssParameter>
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
sld:Title739 - 1006</sld:Title>
ogc:Filter
ogc:Or
ogc:Literal10</ogc:Literal>
ogc:Literal11</ogc:Literal>
ogc:Literal12</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:Fill
<sld:CssParameter name=“fill”>#48af60</sld:CssParameter>
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
sld:Title> 1007</sld:Title>
ogc:Filter
ogc:Or
ogc:Literal13</ogc:Literal>
ogc:Literal14</ogc:Literal>
ogc:Literal15</ogc:Literal>
ogc:Literal16</ogc:Literal>
</ogc:Or>
</ogc:Filter>
sld:Fill
<sld:CssParameter name=“fill”>#006837</sld:CssParameter>
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
<sld:VendorOption name=“ruleEvaluation”>first</sld:VendorOption>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
Sent: 29 April 2022 17:13
To: Ian Turton ijturton@anonymised.com
Subject: RE: [Geoserver-users] legend not showing in Geoserver
Hi Ian,
Many thanks,
Daniel
To: Daniel Campeao <Daniel.Campeao@anonymised.com>
Ian
Many thanks,
Daniel
Ian Turton
Googling error messages often helps. The relevant bit here is:
Caused by: java.lang.NullPointerException
at java.desktop/sun.awt.FontConfiguration.getVersion(FontConfiguration.java:1262)
at java.desktop/sun.awt.FontConfiguration.readFontConfigFile(FontConfiguration.java:225)
at java.desktop/sun.awt.FontConfiguration.init(FontConfiguration.java:107)
Which led me to:
https://stackoverflow.com/questions/65509533/npe-from-sun-awt-fontconfiguration-getversion-using-apache-fop-jdk-11-on-linux-s
Not having fontconfig is common in stripped down docker images (alpine I assume?)
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
That is not valid XML. Problems with tag matching etc.
Try something like https://codebeautify.org/xmlvalidator to find and sort out the issue.
Ngā mihi, Nā Phil Scadden
Te Raraunga me te Tātaritanga Mokowā Aronuku (Geospatial Data and Analysis)
GNS Science Te Pῡ Ao
764 Cumberland St, Private Bag 1930,
Dunedin, New Zealand Ph +64 3 4799663, 027 3463185
“Whāia te iti kahurangi ki te tūohu koe me he maunga teitei”
From: Daniel Campeao via Geoserver-users geoserver-users@lists.sourceforge.net
Sent: Saturday, 30 April 2022 7:07 AM
To: Ian Turton <ijturton@…84…>
Note: External sender:
sld:NamedLayer
sld:UserStyle
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
sld:Rule
ogc:Filter
ogc:Or
</ogc:Or>
</ogc:Filter>
sld:Fill
</sld:Fill>
sld:Stroke
</ogc:Function>
</ogc:Function>
</sld:CssParameter>
</sld:Stroke>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Hi Ian,
Many thanks,
Daniel
To: Daniel Campeao <Daniel.Campeao@…11446…>
Ian
Many thanks,
Daniel
Ian Turton
