Hello List!
I try to use libjpeg-turbo extension on geoserver 2.20.3 but dont work. On geoserver log I see the following message:
2023-02-25 09:47:07,831 DEBUG [org.geoserver.map.turbojpeg] - Encoding input image to write out as JPEG using .
2023-02-25 09:47:07,831 DEBUG [org.geoserver.map.turbojpeg] - Creating a TURBO JPEG writer and configuring it.
2023-02-25 09:47:07,832 DEBUG [org.geoserver.map.turbojpeg] - Writing image out…
2023-02-25 09:47:07,871 DEBUG [org.geoserver.filters] - Not compressing output for mimetype: image/jpeg
2023-02-25 09:47:07,872 WARN [org.vfny.geoserver.servlets] - OutputStream could not be aborted in time. An error has occurred and could not be sent to the user.
2023-02-25 09:47:07,872 ERROR [org.geoserver.ows] -
java.lang.NullPointerException
at javax.media.jai.PlanarImage.getData(PlanarImage.java:2110)
at javax.media.jai.RenderedOp.getData(RenderedOp.java:2276)
at org.geoserver.wms.map.RenderedImageTimeDecorator.getData(RenderedImageTimeDecorator.java:134)
at javax.media.jai.RenderedImageAdapter.getData(RenderedImageAdapter.java:158)
at it.geosolutions.imageio.plugins.turbojpeg.TurboJpegImageWriter.write(TurboJpegImageWriter.java:191)
at org.geoserver.map.turbojpeg.TurboJpegImageWorker.writeTurboJPEG(TurboJpegImageWorker.java:126)
at org.geoserver.map.turbojpeg.TurboJPEGMapResponse.formatImageOutputStream(TurboJPEGMapResponse.java:99)
at org.geoserver.wms.map.RenderedImageMapResponse.write(RenderedImageMapResponse.java:110)
I installed and use this extension 3-5 years ago with Geoserver 2.18
Diferences betwen the two installations, that I found, is Java version: 8 for Geoserver 2.18 and 11 for Geoserver 2.20.
I will apreciate any help!
Thank you.
Gál Zsolt
