[Geoserver-users] Logging GeoServer 2.0.2
Hi list,
I'm wondering if it's possible to increase the size of the log file that GeoServer writes. It seems that the maximum size is 10 MB aprox. but I want to change it to be bigger. Is there any way I can do this?
Thanks in advance.
David Alda Fernández de Lezea
UNIDAD DE EMPRENDIMIENTO Y DESARROLLO RURAL
Area de Sistemas de Información Geográfica, Planificación Territorial y Forestal
Granja Modelo s/n
01192 Arkaute Araba
T 627923170 F 945 003 290
dalda@anonymised.com <blocked::mailto:correo_electronico@anonymised.com> | www.hazi.es <blocked::http://www.hazi.es/&gt;
<file://C:\Documents and Settings\u0899dal\Datos de programa\Microsoft\Signatures\HAZI Consultoria_archivos\image001.jpg>
********************* LEGE OHARRA ******************* AVISO LEGAL ******************* DISCLAIMER ******************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
On Fri, Nov 15, 2013 at 9:25 AM, David Alda Fernandez de Lezea <
dalda@anonymised.com> wrote:
Hi list,
Yes, the logging profiles you have on the user interface are actually names
of log4j configuration
files in $DATA_DIR/logs
Edit them, set a different rolling size, and save them.
Then either restart GeoServer, or change the logging profile to force
GeoServer to reload said
files
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
