On Wed, Apr 18, 2018 at 7:09 PM, Todd Jacobus <tj@anonymised.com> wrote:
This is good advice, especially with my tendency to break things :). I’m searching for where exactly to reconfigure filter chains… would this be in the applicationContext.xml as noted in the docs (I can’t actually find this file)? Obviously, I’m not trying to add a new, custom button, so should I then be looking in config.xml at the top of the security directory? Thank you.
Todd
On Wed, Apr 18, 2018 at 8:25 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
And yes, working with the security subsystem can be pretty painful, it’s rich, but also full of thorns,
so when playing with it take care and backup the security subdir of the data directory
On Wed, Apr 18, 2018 at 4:15 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Wed, Apr 18, 2018 at 4:13 PM, Todd Jacobus <tj@anonymised.com> wrote:
Interesting! I wonder why they built it that way.
That’s pretty simple, because if you removed the form auth there is no point in having those buttons, they would not work at all
If you have another auth, it should have its own UI that does the right calls in order to log you out (which are not at all the same as the form auth).
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
