[Geoserver-users] making a very large imagemosaic - store creation is killed- more resources needed?
Hi all
I’m attempting to create a very large imagemosaic in Geoserver 2.10.2.
The process goes like:
1. add the MODIS sinusoidal projection (http://spatialreference.org/ref/sr-org/6974/geoserver/) to user_projections and netcdf_projections
2. use CreateIndexer.jar (http://geoserver.geo-solutions.it/downloads/releases/2.8.x-netcdf/CreateIndexer.jar) to generate an indexer.xml and _auxiliary.xml for the underlying files
3. check that permissions are all correct on the data store (a directory of many netCDF files)
4. check that my datastore.propoerties file is all correct
5. use the imagemosaic web UI create a store
What happens? Geoserver dutifully trundles off, tells me it’s busy and starts writing to the relevant database tables.
The tables have data, including geometries:
select * from bare_soil limit 10;
fid | the_geom | imageindex | location | time
   1 | 01030000000100000005000000D2F3B5D18E1673C100E0D6EF17F86CC0D2F3B5D18E1673C13964C84576F83041A3754DF1F80672C13964C84576F83041A3754DF1F80672C100E0D6EF17F86CC0D2F3B5D18E1673C100E0D6EF17F86CC0 | 80 | /local/geoserver_data/gdata/fr5/FC.v302.MCD43A4/FC.v302.MCD43A4.h00v08.2000.005.nc | 2000-02-18 11:00:00
   2 | 01030000000100000005000000D2F3B5D18E1673C100E0D6EF17F86CC0D2F3B5D18E1673C13964C84576F83041A3754DF1F80672C13964C84576F83041A3754DF1F80672C100E0D6EF17F86CC0D2F3B5D18E1673C100E0D6EF17F86CC0 | 81 | /local/geoserver_data/gdata/fr5/FC.v302.MCD43A4/FC.v302.MCD43A4.h00v08.2000.005.nc | 2000-02-26 11:00:00
…and the geometries actually hold data (whether they are correct I have to check - but for the moment I dangerously assume that they are):
select st_astext(the_geom) from bare_soil limit 10;
        st_astext
POLYGON((-20015341.106922 -231.752921981504,-20015341.106922 1112182.27258898,-18902927.081411 1112182.27258898,-18902927.081411 -231.752921981504,-20015341.106922 -231.752921981504))
….but no store is ever created.
There are just over 9k tiles, in 4D (ie each tile has X, Y, and time axes). The DB tables get to about 51mb for each ‘layer’ publishable from the tiles.
The only clue I have found in catalina.out is this:
[gce.imagemosaic] - Unable to close indexingnull
…which leads to a post about geoserver needing an EPSG: code: https://osgeo-org.atlassian.net/browse/GEOS-7201 - but this is apparently resolved.
Geoserver’s own log (geoserver-home/logs/geoserver.log) shows me that the mosaic construction is cancelled (see below).
Do I need to:
a. give geoserver more resources?
b. somehow give tomcat more time before it kills processes (no idea if this is a setting I can change or if it’s even relevant)
c. provide more detail?
It’s a single geoserver instance, with Xms 8g, Xmx 8g, G1Gc garbage collection, on a 16GB/8CPU VM. I can make some swap space (it’s on SSD), and expand the heap size if needed - but that might be silly Java management.
Thoughts/suggestions welcome!
Thanks
Adam
(geoserver.log output)
2017-03-18 20:52:36,788 WARN [gce.imagemosaic] - Failure occurred while collecting the granules
org.apache.commons.io.DirectoryWalker$CancelException: Operation Cancelled
  at org.apache.commons.io.DirectoryWalker.checkIfCancelled(DirectoryWalker.java:395)
  at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:368)
  at org.apache.commons.io.DirectoryWalker.walk(DirectoryWalker.java:335)
  at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.<init>(ImageMosaicDirectoryWalker.java:114)
  at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker.run(ImageMosaicDirectoryWalker.java:197)
  at org.geotools.gce.imagemosaic.Utils.createMosaic(Utils.java:450)
  at org.geotools.gce.imagemosaic.Utils.checkSource(Utils.java:1310)
  at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:532)
  at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:479)
  at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:502)
  at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:97)
  at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1493)
  at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1423)
  at org.geoserver.catalog.impl.CoverageStoreInfoImpl.getGridCoverageReader(CoverageStoreInfoImpl.java:59)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:498)
  at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:147)
  at com.sun.proxy.$Proxy13.getGridCoverageReader(Unknown Source)
  at org.geoserver.web.data.layer.NewLayerPageProvider.getItemsInternal(NewLayerPageProvider.java:95)
  at org.geoserver.web.data.layer.NewLayerPageProvider.getItems(NewLayerPageProvider.java:61)
  at org.geoserver.web.wicket.GeoServerDataProvider.fullSize(GeoServerDataProvider.java:243)
  at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.updateMatched(GeoServerTablePanel.java:583)
  at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.<init>(GeoServerTablePanel.java:576)
  at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:176)
  at org.geoserver.web.wicket.GeoServerTablePanel.<init>(GeoServerTablePanel.java:97)
  at org.geoserver.web.data.layer.NewLayerPage$1.<init>(NewLayerPage.java:105)
  at org.geoserver.web.data.layer.NewLayerPage.<init>(NewLayerPage.java:105)
  at org.geoserver.web.data.store.CoverageStoreNewPage.onSuccessfulSave(CoverageStoreNewPage.java:86)
  at org.geoserver.web.data.store.CoverageStoreNewPage.onSave(CoverageStoreNewPage.java:74)
  at org.geoserver.web.data.store.AbstractCoverageStorePage$1.onSubmit(AbstractCoverageStorePage.java:122)
  at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:110)
  at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1307)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:974)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:795)
  at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:171)
  at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
  at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:588)
  at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source)
  at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241)
  at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248)
  at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234)
  at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
  at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
  at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
  at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
  at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
  at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
  at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
  at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
  at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:870)
  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
  at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
  at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
  at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:94)
  at org.geoserver.flow.ControlFlowCallback.doFilter(ControlFlowCallback.java:252)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
  at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
  at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
  at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
  at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
  at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
  at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
  at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
  at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
  at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
  at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
  at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
  at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
  at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
  at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
  at org.apache.coyote.ajp.AjpAprProcessor.process(AjpAprProcessor.java:188)
  at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
  at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2517)
  at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2506)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
  at java.lang.Thread.run(Thread.java:745)
Hi Adam,
can you provide us additional logging? (looking for something which cancel the directory walking if available).
In general, when dealing with similar big datasets, configuring stores via REST would be better.
You can take a look on these page to get some information on that topic:
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html#uploading-and-modifying-a-image-mosaic
http://geoserver.geo-solutions.it/edu/en/multidim/rest/index.html
As an instance, you could start configuring a store on top of a set of sample granules and then harvest additional ones.
Please, let us know.
Daniele
On Sun, Mar 19, 2017 at 11:26 PM, Adam Steer <Adam.Steer@anonymised.com> wrote:
Hi all
st_astext
Do I need to:
Thanks
Adam
at org.geotools.gce.imagemosaic.ImageMosaicDirectoryWalker$MosaicDirectoryWalker.(ImageMosaicDirectoryWalker.java:114)
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:479)
at org.geoserver.web.wicket.GeoServerTablePanel$PagerDelegate.(GeoServerTablePanel.java:576)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:176)
at org.geoserver.web.wicket.GeoServerTablePanel.(GeoServerTablePanel.java:97)
at org.geoserver.web.data.layer.NewLayerPage$1.(NewLayerPage.java:105)
at org.geoserver.web.data.layer.NewLayerPage.(NewLayerPage.java:105)
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hi Daniele
I’ll take a look - it may be that I’ve missed an out-of-memory kill and should check more generic system logs.
But first I’ll try this:
It seems a lot saner to build a small index then add more granules - and i didn’t know geoserver could do that!
Iterating through the files (or file subsets, say by year) would probably avoid memory issues, and give me more time to make coffee...
Will do, thanks for the suggestions.
Regards
Adam
