If I add a FeatureType by creating a folder and info.xml file, how can I get
GeoServer to load the new FeatureType without going to the admin tool?
Along the same lines, is there a way to generate a bounding box for a new
FeatureType without the admin tool?
Richard
(sorry if this is a resend - first one got bounced)
http://docs.codehaus.org/display/GEOSDOC/Alternative+for+reloading+the+Geoserver+catalog
If you're in java you can use the same code that we do. It's on the public subversion repository. I think we used to have the option to put 'generate' for the bounds, but I think we took the option out when we got it in the admin tool. It would be a good thing to have though, you can open a request in our jira task tracker for it.
best regards,
Chris
Richard
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
!DSPAM:1003,45390a7889591804284693!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
