[Geoserver-users] Making imagemosaic through GeoServer REST API
Hello All,
I am trying to use the REST API to dynamically configure an imagemosaic layer from GeoTIFF images, but without success. I have zipped up the .shp, .shx, .dbf and .prj files of the index shapefile and the properties file and have tried issuing a PUT request, as follows:
$.ajax({
type: “PUT”,
url: proxyurl + “http://localhost:8080/geoserver/rest/workspaces/jflow/coveragestores/test1/file.imagemosaic”,
data: "test1.zip,
contentType: “application/zip”,
success: function(resp) {
alert(‘in success’);
complete: function(xReq,txtStatus) {
alert(‘in complete: xReq.status=’ + xReq.status + ’ txtstatus=’ + txtStatus + '; responseText= ’ + xReq.responseText);
if (xReq.responseText.indexOf(“201”) != -1) {
alert(‘Completed make ImageMosaic’);
GeoServer gets as far as making a coveragestore for test1 but the url is defined as “file:data/test1/test1.imagemosaic” which generates an error in the logs (java.lang.IllegalArgumentException: /C:/Program%20Files/GeoServer%202.0.2/data_dir/data/test1/test1.imagemosaic is not one of the files types that is known to be associated with a shapefile).
I have read the thread (http://old.nabble.com/Reload-Mosaic-CoverageStore-Coverage-after-shp-properties-file-has-been-modified-td23928766.html) so it seems it is possible to do but I must be doing something wrong.
My questions are:
· Do I just need the one PUT request or should I issue a POST request first to create the coverageStore (and possibly a second to amend the coverage properties)?
· Should the .zip file be placed in the folder where the .tif files are located?
· How does the file.imagemosaic request tell GeoServer where the images are located?
Any help much appreciated, thanks,
Anne
Anne Brookes
Senior Analyst - GIS and System Development
JBA Consulting
JBA Consulting
South Barn
Broughton Hall
Skipton
North Yorkshire
BD23 3AE
United Kingdom
NCE Consultant of the Year 2010
t: +44 (0)1756 799919 | f: +44 (0)1756 799449
JBA is a Carbon Neutral Company. Please don’t print this e-mail unless you really need to.
This email is covered by JBA Consulting’s email disclaimer.
Hi Anne,
There are a couple of different ways to use this endpoint to configure a mosaic in this way. The method you are using is uploading the file directly… which with a mosaic probably won’t work unless you have all the individual files for the mosaic in the zip file… which you probably dont. Or if your shapefile contained absolute paths to all the files but i think usually they are relative. I might be wrong about that.
That said, a method that might work better is to use the endpoint external.imagemosaic. This allows you to specify locations that already exist on the server rather than upload the files directly. In this case you woudl somehow upload all the files for the mosaic (including the shapefile index) to the server, and then call the endpoint to simply configure the coverage in geoserver.
Here are some useful links in the docs for you:
for shapefile but same applies
scroll down until you see:
/workspaces//datastores//file[.]
/workspaces//datastores//url[.]
/workspaces//datastores//external[.]
Hope that helps.
-Justin
On Tue, Jan 25, 2011 at 8:33 AM, Anne Brookes <anne.brookes@anonymised.com> wrote:
Hello All,
$.ajax({
type: “PUT”,
data: "test1.zip,
My questions are:
Anne
Anne Brookes
JBA Consulting
JBA Consulting
South Barn
Broughton Hall
Skipton
North Yorkshire
BD23 3AE
United Kingdom
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thanks for the response. Still not getting it to work though. I have tried:
$.ajax({
type: “PUT”,
url: proxyurl + “http://localhost:8080/geoserver/rest/workspaces/jflow/coveragestores/test1/external.imagemosaic”,
data: “file:///OpenSourceGIS/data/testmosaicREST/test1.shp”,
contentType: “text/plain”, //“application/zip”,
(and various combinations of backslashes, different numbers of forward slashes etc in the data string) but GeoServer only gets as far as making a coverage store and nothing else, and returning an HTTP Server Error 500. I don’t really understand what the external.imagemosaic is supposed to do. Should it make the whole mosaic, as if running the plugin, or would I still have to make a PUT request to define the coverage as well?
In answer to your comments/questions:
There are a couple of different ways to use this endpoint to configure a mosaic in this way. The method you are using is uploading the file directly… which with a mosaic probably won’t work unless you have all the individual files for the mosaic in the zip file… which you probably dont. Or if your shapefile contained absolute paths to all the files but I think usually they are relative.
The zip I was previously using did not contain the tifs (only the shapefile and properties files) but all the files are on the map server – and the index shapefile did contain the absolute paths (but I could change this to relative if important).
Anne
Anne Brookes
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: 25 January 2011 15:47
To: Anne Brookes
Subject: Re: [Geoserver-users] Making imagemosaic through GeoServer REST API
Hi Anne,
Hope that helps.
-Justin
Hello All,
$.ajax({
type: “PUT”,
data: "test1.zip,
My questions are:
Anne
Anne Brookes
Image removed by sender. JBA Consulting
JBA Consulting
South Barn
Broughton Hall
Skipton
North Yorkshire
BD23 3AE
United Kingdom
Image removed by sender. NCE Consultant of the Year 2010
Justin Deoliveira
On Wed, Jan 26, 2011 at 2:05 AM, Anne Brookes <anne.brookes@anonymised.com> wrote:
Hi Justin,
$.ajax({
type: “PUT”,
Hmmm… ok, i would think this should work. Can you include the error you are getting on the server. If you are getting back a 500 you should see a stack trace in the server logs or on the console you are running geoserver.
Anne
Anne Brookes
To: Anne Brookes
Hi Anne,
Hope that helps.
-Justin
Hello All,
$.ajax({
type: “PUT”,
data: "test1.zip,
My questions are:
Anne
Anne Brookes
JBA Consulting
South Barn
Broughton Hall
Skipton
North Yorkshire
BD23 3AE
United Kingdom
Justin Deoliveira
Justin Deoliveira
