Hi List,
Has anyone who’s been using the MapFish printing extension got any config.yaml files they’re willing to share with the community? These seem like the sort of thing that would benefit from being shared as they’re generally going to be fairly generic while they also seem to be a royal pain to create.
I’ve found the samples here, but that seems to be it.
https://trac.mapfish.org/trac/mapfish/browser/print/trunk/samples
Also, does anyone have any suggestions for how to actually debug them? The config files seem incredibly touchy about formatting etc and the exceptions I’m using to debug via GeoServer console are generic and not useful for this sort of thing (i.e.: 25 Jan 18:22:07 ERROR [org.mapfish.print.servlet.BaseMapServlet] - Error while generating PDF java.lang.IllegalStateException: unsupported protocol: ‘d’ ).
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Stephen V. Mather
