[Geoserver-users] matchCase
Hi there,
I’m trying to use the attribute “matchCase” with filter PropertyIsEqualTo in a WFS GetFeature request.
In the body of the WFS request :
<ogc:PropertyIsEqualTo matchCase=“false”>
I get this exception :
java.lang.RuntimeException: Parsing failed for PropertyIsEqualTo: java.lang.classCastException: java.lang.String cannot be cast to java.lang.Boolean
I tried without quotes, with single quotes, on 2.14, 2.17 to no avail
The request works without the attribute matchCase but, I’d like to perform case insensitive requests.
Thanks
Envoyé à partir d’Outlook
I have generated the xml from Openlayers for a WFS getfeature request with the matchCase option set to true. It looks like this:
ROUTE_ID
50927952
Hopefully this helps, admittedly it does not have any alpha characters, but it works
Graham
Sent: Thursday, 20 January 2022 2:56 AM
To: GeoServer Users geoserver-users@lists.sourceforge.net
Subject: [Geoserver-users] matchCase
Hi there,
Thanks
Currently supported GeoServer versions are 2.19.x and 2.20.x. I don’t remember if there was any change
related to PropertyIsEqualTo parsing in earlier versions, you might want to try a more recent one.
From the error, maybe you are trying to use matchCase on a version of WFS that does not
support it? WFS 1.0 uses Filter 1.0, which does not have a matchCase attribute. It was introduced in WFS 1.1
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Andrea,
you are right : changing WFS version to 1.1.0 did the trick.
Thank you very much for your help.
De : Andrea Aime andrea.aime@anonymised.com
Envoyé : 20 janvier 2022 03:46
À : Olivier Gagnon mcnolii@anonymised.com
Cc : GeoServer Users geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] matchCase
On Wed, Jan 19, 2022 at 4:58 PM Olivier Gagnon <mcnolii@anonymised.com> wrote:
Hi there,
Thanks
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
