With Geoserver 2.22.5 I’ve installed the MBStyle extension (and the style editor gives the Mapbox style option in the Geoserver ui) (and the vector tiles plugin). I followed along with the documentation for installing it and creating mapbox styles and I fear I may have missed something for for instance https://docs.geoserver.org/2.22.x/en/user/styling/workshop/mbstyle/polygon.html refers to employing a sprite for a fill pattern :
" You can view the names of all the icons in the sprite-sheet by looking at its json definition, at http://localhost:8080/geoserver/styles/sprites.json." says the docs and that does not seem to exist in my environment, in short there is no “sprites” under styles, and I wonder if there’s supposed to be from merely installing the MBStyle extension or if there’s anything else that need doing.
I can create a sprites file with https://github.com/mapbox/spritezero-cli I think and host it someplace but it seems like the Geoserver docs imply that there’s supposed to be sprites already and I don’t entirely get it and would appreciate a heads-up : )
I am goad you found the workshop; I only update that material (and indeed mbstyle) when I have an opportunity to teach that workshop.
Although I tested the plugin with MapLibre I have not had the opportunity to update the content and plugin to reflect changing from mapbox to maplibre library.
I think you will find that the sprite was available as a download on that page (if not it should be).
Actually I can see that the content is quoted in full as part of that page
But it does not seem to have a download link, or the associated PNG file
Friendly regards
David
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
