I’ll paste an output from jmap -hist below, but I don’t see anything really obvious.
Debugger attached successfully.
Server compiler detected.
JVM version is 25.91-b14
Iterating over heap. This may take a while…
Object Histogram:
On Sat, Dec 10, 2016 at 10:43 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jason,
did you find out what was going on in the end?
Jason Newmoyer
Newmoyer Geospatial Solutions
843.606.0424
jason@anonymised.com
On Wed, Dec 7, 2016 at 9:01 PM, Jason Newmoyer <jason@anonymised.com..> wrote:
Thank you for the thorough response. I will poke around with JMap and see what I can figure out.
The GWC service is indeed the primary endpoint being requested.
I’m also suspect of our memory settings in PostgreSQL. We have tons of memory available and use pgtune to make use of it.
I’ll let you know what I find out.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Jason Newmoyer
843.606.0424
On Sat, Dec 3, 2016 at 4:42 AM, Andrea Aime <andrea.aime@anonymised.com107…> wrote:
On Fri, Dec 2, 2016 at 7:11 PM, Jason Newmoyer <jason@anonymised.com> wrote:
Setup is: RHEL 6, GeoServer (war) 2.10.0, Jetty 9.3, PostgreSQL 9.4, monitoring plugin with hibernate enabled, configured for JNDI datasource provided by Jetty c3p0
I know that saving with hibernate tends to become slower and slower and … slower, but that is related to the inserts themselves
on the table, checking for the primary key uniqueness becomes progressively slower until it becomes completely
unusable. That’s why, at least in my company, we never use the hibernate storage, but enable audit mode to dump
on file instead, and then transfer the info into elasticsearch using logstash.
Database storage progressive slowdown should be fixable by removing the primary key, however that is probably going to require
other changes, I have vague memories that the code might saving a record and then updating it later, which might not work
without a primary key to refer to for the update statement.
System is under pretty heavy use (1000’s of requests per hour) and while the extension does what its intended to do, we end up with an unstable GeoServer after several hours and must be restarted. System reports resident memory slowly increasing unbounded for the java process. At about 2x the max heap size setting it starts to fall over. Services become unreachable and log starts printing huge lists of threads. Even the shutdown signal to Jetty seems to be ignored and the process must be SIGKILL’d.
You should collect a memory dump using jmap when things start getting bad and see what’s filling the memory.
Or just get one using Yourkit, they do have a 15 days trials license which is normally good enough for a one-off analysis.
I’m curious if this has been reported before if anyone can provide leads as to the cause. I checked JIRA and didn’t see anything. I’m willing to peak around in the monitor code.
Also, a lot of our users and using KML superoverlays and this causes about 90% of our requests to be operation=‘dispatch’ which seem completely useless to me. Anyone know what the purpose of that is? I’m interested in making a configuration parameter to ignore these.
I’m not sure about this one… You probably want to check somewhere around here:
https://github.com/geoserver/geoserver/blob/master/src/extension/monitor/core/src/main/java/org/geoserver/monitor/ows/MonitorCallback.java#L77
although you’ll probably also end up looking into the main dispatcher here:
https://github.com/geoserver/geoserver/blob/master/src/ows/src/main/java/org/geoserver/ows/Dispatcher.java
I’m making a guess here, maybe you are hitting some GWC service? Those are not playing by the same rules as the GeoServer inner ones
and I believe that could be a reason why monitoring has troubles figuring out the details
Ing. Andrea Aime
@geowolf
Technical Lead
