Then it seems to be a problem with the height and the width...
Your request works, but If just change the width ad the height:
http://synthesys.csic.es:8080/geoserver/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=tdwg:richness_by_c_square_05&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:41001&BBOX=-20000000,0,0,20000000&WIDTH=256&HEIGHT=256
It doesn't...
In catalina.out apart of:
^@2504 [WARNING] org.geotools.data.postgis.PostgisDataStore - GEOS is
NOT enabled. This will result in limited functionality and
performance.
May 17, 2006 7:08:14 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive mapbuilder.war
May 17, 2006 7:08:17 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
May 17, 2006 7:08:18 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
May 17, 2006 7:08:18 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/28 config=null
May 17, 2006 7:08:18 PM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
May 17, 2006 7:08:18 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 19838 ms
I don't see anything relevant (what is this GEOS by the way...
Javier.
On 5/17/06, Alexander Petkov <greenkov@anonymised.com> wrote:
Hmm, it seems to work here:
http://synthesys.csic.es:8080/geoserver/wms?&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=tdwg:richness_by_c_square_05&STYLES=&FORMAT=image/png&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:41001&BBOX=-20000000,0,0,20000000&WIDTH=1000&HEIGHT=576
I don't know what the reaspect argument does (I removed it), if you
post console output it may reveal more as to what is going on.
Alex
On 5/17/06, Javier de la Torre <jatorre@anonymised.com> wrote:
> Hi,
> I am experimenting now some strange behaviour when using 41001
> projection together with Google Maps.
> For example, look at:
> 41001&BBOX=0,-20000000,20000000,0&WIDTH=256&HEIGHT=256&reaspect=false
> You get the southern hemisphere correctly draw, but with the norther
> it does not work, you get a black image (and believe, there is data)
> 41001&BBOX=-20000000,0,0,20000000&WIDTH=256&HEIGHT=256&reaspect=false
> If you want to see it in a Google Map interface check:
> http://synthesys.csic.es/gmap/SynthesysMap2.php
> And do a total zoom out. you will not get any results (overlay I mean).
> One zoom level up (1) and you get only half of the world, as
> described...
> The total world request would be:
> http://synthesys.csic.es/OGCphpCache/wms_cache.php?
> 41001&BBOX=-20000000,-20000000,20000000,20000000&WIDTH=256&HEIGHT=256&re
> aspect=false
> Any idea?
> Javier.
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
