In theory the standard way to do that with WMS would be to use GetStyles
Unfortunately conversion between the mapfile styles and SLD is poor and the SLD returned by Mapserver is not always even close to the actual styles. This is probably a feature that nobody uses.
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi James,
I don’t think I’ve ever seen mention of a way of automating the migration; might be worth asking on the MapServer list.
I suspect it’s possible to create a tool to do it (read the mapfile and turn it into SLD’s). You’re probably going to have to do it manually though.
Jonathan
On 25 February 2014 20:10, EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <james.evans.4@anonymised.com> wrote:
I’m thinking of migrating my MapServer MS4W service over to GeoServer. The MS4W comes with Apache and PHP that are out of date, and I don’t seem to be able to update them without breaking the mapserver. Are there any guides on migrating a mapserver mapfile over to be served up by GeoServer?
James
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
