[Geoserver-users] Mongodb Extension
The mongodb extension is currently labeled as unsupported. Are there any plans to update the mongodb extension for the latest Mongo geospatial features and support the extension?
Nathan
I have exported a simple sld from qgis – it didn’t work in 2.6.2 so I tried 2.7.0
Are they not supported or have I set something up wrong ?
The error generated is :-
java.io.IOException: java.lang.RuntimeException: Parsing failed for Filter: java.lang.RuntimeException: Unable to find function Literal java.lang.RuntimeException: Parsing failed for Filter: java.lang.RuntimeException: Unable to find function Literal Parsing failed for Filter: java.lang.RuntimeException: Unable to find function Literal Unable to find function Literal
And from the log :-
Caused by: java.lang.RuntimeException: Unable to find function Literal
at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:205)
at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:152)
at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:127)
at org.geotools.filter.FilterParsingUtils.lookupExtendedOperator(FilterParsingUtils.java:170)
at org.geotools.filter.FilterParsingUtils.parseExtendedOperators(FilterParsingUtils.java:139)
at org.geotools.filter.v1_1.FilterTypeBinding.parse(FilterTypeBinding.java:111)
at org.geotools.xml.impl.ParseExecutor.visit(ParseExecutor.java:155)
… 127 more
SLD :-
se:NameAdvisory_Disabled_Bays</se:Name>
se:FeatureTypeStyle
se:Rule
se:NameSingle symbol</se:Name>
se:PolygonSymbolizer
se:Fill
<se:SvgParameter name=“fill”>#ffffff</se:SvgParameter>
</se:Fill>
se:Stroke
<se:SvgParameter name=“stroke”>#728584</se:SvgParameter>
<se:SvgParameter name=“stroke-width”>0.26</se:SvgParameter>
<se:SvgParameter name=“stroke-linejoin”>bevel</se:SvgParameter>
</se:Stroke>
</se:PolygonSymbolizer>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:WellKnownNamehorline</se:WellKnownName>
se:Stroke
<se:SvgParameter name=“stroke”>#000000</se:SvgParameter>
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
<ogc:Filter xmlns:ogc=“http://www.opengis.net/ogc”>
ogc:Literal45</ogc:Literal>
</ogc:Filter>
</se:Rotation>
se:Displacement
se:DisplacementX0.850904</se:DisplacementX>
se:DisplacementY0.525322</se:DisplacementY>
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:Stroke
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
ogc:Literal135</ogc:Literal>
</ogc:Filter>
</se:Rotation>
se:Displacement
se:DisplacementX0</se:DisplacementX>
se:DisplacementY0</se:DisplacementY>
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
</se:Rule>
</se:FeatureTypeStyle>
Mark Ismail
Hi Nathan,
You might check out Boundless’s MongoDB support: https://github.com/boundlessgeo/geoserver-exts/tree/master/mongodb.
They’d likely be willing and excited to discuss paid support.
Jim
Nathan
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
[http://ad.doubleclick.net/ddm/clk/290420510;117567292;y](http://ad.doubleclick.net/ddm/clk/290420510;117567292;y)
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
On Thu, May 7, 2015 at 5:27 PM, Ismail, Mark <mark.ismail@anonymised.com>
wrote:
<se:Rotation>
                    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
                      <ogc:Literal>135</ogc:Literal>
                    </ogc:Filter>
                  </se:Rotation>
The above is not valid, no wonder it cannot be parsed, QGis SLD generation
is known to emit invalid sld, and/or to use qgis specific extensions.
For a transfer of SLDs from QGis to GeoSever we'd need a two sided effort:
* QGis should generate at least valid SLD (the one above is not)
* GeoServer should learn how to interpret QGis specific extensions to SLD
(e.g. their symbol names and the like)
These issues come up often enough that I'm surprised no one has sponsored
some work in this area yet.
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
That isn’t a valid filter. Looks like another QGIS bug.
Ian
And from the log :-
… 127 more
SLD :-
se:FeatureTypeStyle
se:Rule
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:Stroke
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
</ogc:Filter>
</se:Rotation>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:Stroke
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
</ogc:Filter>
</se:Rotation>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
</se:Rule>
Mark Ismail
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y_______________________________________________
Hello Andrea and Ian,
thank you very much for your description concerning the compatibility of QGIS’s SLDs in GeoServer.
Actually, I didn’t get to work nary a SLD of QGIS in GeoServer over the past semesters/years. But QGIS’s style editor is a powerful tool and you can create nice SLD styles by categorization based on attributes. This is important in geo sciences to create a soil map for instance.
Is there an alternative way to create great looking complex SLDs for GeoServer?
Best wishes,
Izabella
Ian
And from the log :-
… 127 more
SLD :-
se:FeatureTypeStyle
se:Rule
se:Fill
</se:Fill>
se:Stroke
</se:Stroke>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:Stroke
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
</ogc:Filter>
</se:Rotation>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
se:Fill
se:GraphicFill
se:Graphic
se:Mark
se:Stroke
</se:Stroke>
</se:Mark>
se:Size2</se:Size>
se:Rotation
</ogc:Filter>
</se:Rotation>
se:Displacement
</se:Displacement>
</se:Graphic>
</se:GraphicFill>
</se:Fill>
</se:Rule>
Mark Ismail
