Hi List,
I’m interested in monitoring several aspects of GeoServer using NAGIOS. The thing that’s stumping me is how to get the number of requests the server is receiving.
I’m aware of the monitoring plugin, and have set it up to act as a “live” system, which works because I don’t want it to keep logs, I have them elsewhere.
The problem is, the plugin in this configuration doesn’t seem to want to provide me with any useful information in response to my queries. Certainly not current number of queries per second or something.
I considered using the rest interface, but it only ever returns 100 results, no matter what “count” is set at (I’d report that as a bug, but ironically JIRA is bugging out so later)
Is it possible to do this with GeoServer? How do I do it?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
