Hi Simone,
I found the cause for this error message.
First I opened webadmin interface. Then I clicked 'Layer Preview', then 'Openlayers' at the 'sf:sfdem' line. What I got was the error I reported. Let me tell where it came from:
I have a habbit to rename war package according to the version, like gs202 instead of geoserver. But the styler wouldn't work with gs202, so I created a symbolic link called geoserver refering to gs202. After that I tried to preview layers with address http://localhost:8080/geoserver/. That gives me the error. But if I try with the address http://localhost:8080/gs202/, layer preview works, but the styler doesn't, it wont find the capabilities doc.
Obviously I have to get rid of my habbit to rename geoserver packages. It's just that I am often running several versions of Geoserver instances at a same Tomcat. Renaming them with a version is practical.
Thanks and sorry for false alarm.
- mika -
Simone Giannecchini kirjoitti:
Ciao Mika,
I am not sure I understood what you are reporting. Can you be more specific?
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Fri, May 28, 2010 at 11:19 AM, Lehtonen, Mika <mika@anonymised.com> wrote:
GS 2.02. I tried to preview sfdem demo. I got this. Same goes with my
own similar like efforts. With the style named 'raster' (without
ColorMap), grayscale image is rendered.
2010-05-28 13:08:16,805 ERROR [geotools.rendering] -
org.geotools.coverage.processing.CoverageProcessingException:
java.lang.IllegalArgumentException: org.geotools.RasterClassifier -
Parameter value`s class
(org.geotools.renderer.lite.gridcoverage2d.LinearColorMap) is not an
instance of the parameter class
(org.geotools.renderer.lite.gridcoverage2d.ColorMapTransform) for
parameter "Domain1D".
- mika -
Geoserver-users mailing list
Mika Lehtonen
XML-Scanning Littoinen Ky
Lankakatu 2 E 13, 20660 Littoinen
mika@anonymised.com
mbl +358 (0)44 2908259
