Im trying to create a Mosaic of GeoTiff images. Following instructions from
http://docs.codehaus.org/display/GEOSDOC/Using+the+ImageMosaic+plugin
Ive managed to download and compile MosaicIndexBuilder into a jar using
Eclipse. However when i run any commands nothing happens. Is there any
more information on building it/running it.
Any help would be grateful.
Thankyou
View this message in context: http://www.nabble.com/Mosaic-Index-Builder-tf4948929.html#a14169509
Hi pjtmoore,
in the web page you mentionned, there is all you need in fact.
You can add the following parameters when you run this class into your Eclipse :
-s <source_directory> -w *.tif -name mosaic
This will normally generate a shape file, called "mosaic.shp", using all the tif files you have in the specified directory.
This shape file is just a grid where the whole tiff images will be placed.
You can then try using the Mosaic plugin of Geoserver, giving this shape file (if I remember well).
Cédric B.
Thankyou
