Dear Simone,
Thank you again!
Perhaps you misunderstood, I’m comfortable with a commandline utility, a GUI isn’t required. However, getting the SVN code, and compiling the Java code, is a little beyond me right now.
Do you have a pre-built MosaicIndexBuilder.exe for Windows?
If you want to try the sample:
http://www.topodepot.com/topodepotdownload/doqmrsid/raster_roger.zip
Roger
Roger Bedell, President Sylvan Ascent Inc.
800-362-8971
+34 626 855 662
roger@anonymised.com
www.sylvanascent.com
www.topodepot.com
From: Simone Giannecchini [mailto:simboss1@anonymised.com]
Sent: Thu 10/23/2008 10:35 AM
To: Sylvan Ascent Inc.
Subject: Re: [Geoserver-users] Mosaicing MrSids
On Thu, Oct 23, 2008 at 4:09 PM, Sylvan Ascent Inc.
sylvanascent@anonymised.com wrote:
Thanks Simone,
Is this still true, that we have to build MosaicIndexBuilder to use it?
Actually, yeah, it would be quite easily to buila GUI around the
coverage tools since they basically are structured in a way that tehy
can be run from Swing. The motivation to build such a GUI has always
been there, while time has always been a problem, I guess :-).
And
will it work with MrSID?
Yeah.
If you have some test data to share, I can check with such test data.
Simone.
Using MosaicIndexBuilder
This tool is authored by Simone Giannecchini, and can be found in the
Geotools Subversion repository
http://svn.geotools.org/trunk/modules/unsupported/coveragetools
Advantages: All-in-one solution–no need to manually edit and create
.properties or a .prj file.
Disadvantages: Requires you to download and build the tool. However, this is
easily accomplished if you have Eclipse installed, and a SVN checkout of
gt-trunk.
800-362-8971
+34 626 855 662
www.topodepot.com
Sent: Thu 10/23/2008 9:55 AM
Yeah,
I have been using them that way lately.
I need probably to back port a few fixes on the coveragetools from
geotools trunk, but I have had feedback from a few users on using
mosaic of mrsid files.
Simone.
On Thu, Oct 23, 2008 at 3:36 PM, Sylvan Ascent Inc.
Well, now the MrSID plugin works, onto the next step.
Can I use the ImageMosaicing with MrSID files? or what would be the
prefered way to create a Coverage Data Set of a bunch of overlapping MrSid
files?
800-362-8971
+34 626 855 662
www.topodepot.com
This SF.Net email is sponsored by the Moblin Your Move Developer’s
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.geo-solutions.it/simone.giannecchini
http://www.linkedin.com/in/simonegiannecchini
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
