It probably involves fixing the code. Are you working with Ian Turton on this? You're at Penn State with him, yeah? He wrote a lot of the original SLD code - this may have just not made it in. I know there's another deficiency with SLD text stuff, we don't properly concat tags, we just use the first one in a label.
Chris
Scott Pezanowski wrote:
Brent,
I tried adding the tag you suggested and this did not solve the problem. Does anyone else have any ideas?
Scott
To: Scott Pezanowski
CC: geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] multiple textsymbolizers within the
same rule
Date: Wed, 30 Aug 2006 11:45:45 -0700
I'm pretty sure you can have multiple text symbolizers in the same rule,
and looking at the code it does appear to be true.
But what might be happening is that the labeling will hide colliding
labels, so you don't get a cluttered map. You can make sure your text
symbolizer vendor option
0
is set to zero.
But still, looking at the code, I think that only one is rendered.
Can anyone else shed some more light on the LabelCache and
StreamingRenderer?
Brent Owens
(The Open Planning Project)
> Hi,
> We are trying to display a symbol for points from a truetype font
> through geoserver. The symbol is actually composed of three
characters
> from the font, laid on top of each other. To do this with geoserver,
> we have tried creating three different rules for each character and
> also three different textsymbolizers for the same rule (as seen
> below). In both cases, the problem is that geoserver only
displays the
> last character listed in the sld. We thought that perhaps the last
> character was blocking out the others but this does not seem to
be the
> case. First, is what I'm trying to do possible with sld? Second, can
> anyone see what I am doing wrong?
> We could create an image of the symbol and use that; However, I
do not
> see that as the ideal solution.
> Thanks in advance for any help,
> Scott
> L-PLNT-TXST-DECI
> layer
> L-PLNT-TXST-DECI
> õ
> ESRI US MUTCD 3
> 18
> #969696
> 0.5
> ô
> ESRI US MUTCD 3
> 18
> #00A639
> 0.5
> ó
> ESRI US MUTCD 3
> 18
> #9D4F21
> 0.5
> Using Tomcat but need to do more? Need to support web services,
security?
> Get stuff done quickly with pre-integrated technology to make
your job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
> Geoserver-users mailing list
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
security?
Get stuff done quickly with pre-integrated technology to make your
job easier
Geronimo
!DSPAM:1003,44f5df4e315294820651628!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
Chris Holmes
http://topp.openplans.org
