[Geoserver-users] multiple users on one server - maintain separate resources
I need to have one server available to multiple users, each with their own
set of geoserver resources. Is this directly supported? How?
If it's not supported, are there suggestions for workarounds?
Thanks.
Oz
  If it's not supported, are there suggestions for workarounds? Thanks.
Oz
Being able to use several data directories from the same instance is on our wishlist (past 2.0 I think), but it's currently not possible.
Do you need separate resources for convenience (i.e. limit what they see) or for security purposes?
See http://geoserver.org/display/GEOSDOC/2.6+Security+subsystem
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
(CCing list again)
I still don't have an entirely clear picture of what you are trying to achieve, but it sounds like you basically want to do hosting for completely independent users.
Until multiple data directories are supported you will need one instance per user. It is not hard to do, just install Tomcat and then load several copies of the servlet, but it requires a fair amount of memory. (See http://geoserver.org/display/GEOSDOC/2.6+GeoServer+in+Production+Environment )
-Arne
Dear Arne,
Thanks very much for the answer.
We need to keep separate resources to prevent *collision* that can result from sharing. One user might modify a resourse, that another user requires.
We also need to keep the list of resources *simple* for our minimally-trained users.
We're also worried about collisions on the *catalog file* that keeps the list of geoserver resources.
*Security* is not a big issue now, but it will probably grow in the future as the number of users increases.
Oz
-----Original Message-----
Sent: Wednesday, 11 February, 2009 1:45 AM
To: tdigennaro@anonymised.com
Subject: Re: [Geoserver-users] multiple users on one server - maintain separate resources
> Thanks.
> Oz
-Arne
Arne Kepp
Arne Kepp
Dear Arne,
Thanks. Not "completely independent" users.
Our users are partially independent and partially sharing.
I understand about multiple instances - we're not sure that we can support
that load. We're working on a project that must work in the field and on an
LAN, without large computer resources (minimal computers).
Oz
Sent: Wednesday, 11 February, 2009 8:39 AM
To: tdigennaro@anonymised.com; geoserver-users
separate resources
(CCing list again)
(See
-Arne
Dear Arne,
user requires.
Oz
separate resources
their own
> Thanks.
> Oz
-Arne
Arne Kepp
Arne Kepp
Thomas DiGennaro ha scritto:
Dear Arne,
Mumble,
it would help to know what your "users" exactly are going to do.
Are they simply external groups that need to have each its own
wms capabilities document?
Or are they going to admin GeoServer as well, so we have a group
of administrator level users?
Andrea Aime
