Thank you very much for the data. However, the file (sst.nc) you sent had 1D coordinates. These kinds of coordinates are okay in GeoServer:
lat_1D: float32 lat(y)
lon_1D: float32 lon(x)
The latitudes and longitudes in a 2D NetCDF data have 2D shapes, and they depend on both the x and y axis. They are problematic in GeoServer, although in the documentations it is mentioned that they can be handled):
lat_2D: float32 lat(x,y)
lon_2D: float32 lon(x,y)
On Thu, May 4, 2023 at 5:09 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, May 4, 2023 at 3:09 PM Amirhossein Nikfal <ah.nikfal@anonymised.com> wrote:
Well actually in the documentation it has been mentioned that GeoServer can handle NetCDF data with 2D coordinates (latitudes/longitudes).
A scalar variable with lat and lon? Sure, it’s supported.
When you said a 2D variable, I understood you wanted a vector-type variable (not sure if NetCDF even supports it, TBH).
I just want a sample NetCDF data with 2D coordinates to test it.
This tiny NetCDF used for the NetCDF module tests should do the trick:
https://github.com/geoserver/geoserver/raw/main/src/extension/netcdf/src/test/resources/org/geoserver/netcdf/test-data/sst.nc
Regards
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
