[Geoserver-users] NetCDF store
We've just installed Geoserver 2.8-SNAPSHOT and we would like to use
it to display NetCDF files (model output).
However there is no NetCDF store in the Raster Data Source section.
How can I add it?
Andres
Andres Sepulveda | Director, Geophysics Department
University of Concepcion | Casilla 160-C Concepcion CHILE
Andres,
please install the GeoServer NetCDF plugin, listed under the "Coverage Formats" section of the download page:
http://geoserver.org/release/2.8.x/
http://ares.boundlessgeo.com/geoserver/2.8.x/ext-latest/geoserver-2.8-SNAPSHOT-netcdf-plugin.zip
(Not to be confused with the NetCDF output plugin (netcdf-out) in the "Output Formats" section, which is used to create NetCDF responses.)
Once you have installed the plugin, you will need to restart GeoServer.
Kind regards,
Ben.
On 22/09/16 07:48, Andres Sepulveda wrote:
How can I add it?
Andres
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
NetCDF support is a GeoServer extension that needs to be installed as an add-on to the base GeoServer installation:
If you are compiling GeoServer you need to use the netcdf profile which includes the NetCDF extension:
mvn clean install -T4 -Pnetcdf
I see that you are using GeoServer 2.8 note that the current stable version is GeoServer 2.9, you can download
NetCDF extension for GeoServer 2.8.x from here: http://geoserver.org/release/2.8.x/
Hope this helps.
Nuno Oliveira
On 09/21/2016 08:48 PM, Andres Sepulveda wrote:
How can I add it?
Andres
Visit GeoSolutions Enterprise Support Services for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
  The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
