[Geoserver-users] NetCDF Support
It seems I have seen a lot about improved/new NetCDF support in GeoServer change logs, release, notes, etc. lately. However, I don’t seem to be able to uncover any documentation on how to actually use NetCDF as a data source in GeoServer.
Can someone point me in the right direction?
Mike Grogan
Hello Mike,
currently the NetCDF stuff is not yet fully backported to GeoServer 2.4.x, so basically for a while building the NetCDF stuff and using it can be done only through some GeoServer forks around.
In any case, if you want to do some tests and start playing with it, here
https://github.com/geosolutions-it/educational/blob/master/multidim/en/get_started/geoserver_multidim_basics.rst
there are some instructions on how to build locally a GeoServer Multidimensional.
Also the same address contains a full opensource workshop demonstrating step-by-step the use of Multidimensional plugins other than import/export of NetCDF files.
A ready to use Tomcat with GeoServer Multidim is also available through the Multidim Workshop binaries here:
64 bit → http://geoserver.geo-solutions.it/downloads/training/windows/64/multidim/
32 bit → http://geoserver.geo-solutions.it/downloads/training/windows/32/multidim/
Hope this helps.
-A.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Sep 30, 2013 at 8:11 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
Mike Grogan
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60133471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Mike,
It looks like it’s a community module, so documentation may be lacking. I guess maybe it comes from these folks - http://geocentlabs.com/geoserver-netcdf-reader/ you could try asking them directly?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On 30 September 2013 19:11, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
Mike Grogan
On Tue, Oct 1, 2013 at 11:31 AM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi Mike,
It looks like it's a community module, so documentation may be lacking. I
directly?
Actually, that's not the NetCDF module that is going to be used in
GeoServer.
It's sort of a sorry story, that group created a netcdf reader quite some
time ago, but they were very late (one year or more) to contribute it
to the community, at which point GeoSolutions already started working on
another NetCDF reader, which is the one that we are going
to use in the future, mostly because the geocent one lacks some features
and some performance optimizations, but also because we
are familiar with the one we wrote, while geocent has not stepped up to
provide long term support for their own
At the moment the NetCDF reader still has to be built from sources, let me
see if we can add it to the nightly builds shortly.
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thanks for the update. I will try to work with this soon. Unfortunately, the first link is a 404 for me.
  • Mike Grogan
On Mon, Sep 30, 2013 at 5:36 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hello Mike,
Hope this helps.
-A.
more information.
@alfa7691
Mike Grogan
Oh I see, however the same documentation of the link is available as HTML on the docs.zip files of the workshop.
more information.
@alfa7691
On Wed, Oct 2, 2013 at 4:49 PM, Mike Grogan <d.michael.grogan@anonymised.com> wrote:
  • Mike Grogan
Hello Mike,
Hope this helps.
-A.
more information.
@alfa7691
Mike Grogan
Dear Mike,
the link where too early, we are actively working on merging the basic
workshop with the advanced ones (multidim and , hence don't use the
provided links for the moment.
If you are following on the devel list, daniele is pushing the
remaining bits of the work + plus the GeoServer basic documentation.
The workshop is far more advanced & complete.
So, yeah, be patient a little bit more :slight_smile:
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
- Mike Grogan
Hello Mike,
Multidimensional.
NetCDF files.
64 bit ->
32 bit ->
Hope this helps.
-A.
more information.
@alfa7691
change logs, release, notes, etc. lately. However, I don't seem to be able
in GeoServer.
Mike Grogan
from
from
http://pubads.g.doubleclick.net/gampad/clk?id=60134791&iu=/4140/ostg.clktrk
