[Geoserver-users] No download for ArcSDE Plugin
Hi!
Does anybody know what’s wrong with the ArcSDE Plugin (ArcSDE)? It seems like there is no download or successful build available. Thanks!
Best,
Monika
the ArcSDE plugin has dropped out of support, due to lack of a maintainer (which in turn happened due to lack of business around the datastore).
In 2.17.x the plugin can still be found among the “community modules”, ready to be used along with a GeoServer 2.17.x nightly build:
https://build.geoserver.org/geoserver/2.17.x/community-latest/
Same happens for 2.18.x:
https://build.geoserver.org/geoserver/2.18.x/community-latest/
In the upcoming 2.19.0 the store has been completely removed. If you know anyone that is willing to maintain the plugin (or is interested
in sponsoring its re-integration in the source code, and the necessary maintenance), then it would be possible to bring it back,
the old sources are still in the version control history.
On Tue, Mar 2, 2021 at 2:10 PM Senn Monika <Monika.Senn@anonymised.com…> wrote:
Hi!
Best,
Monika
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Regards, Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Andrea!
Thank you very much for your quick & very helpful reply!
Monika
On Tue, Mar 2, 2021 at 2:10 PM Senn Monika <Monika.Senn@…10713…> wrote:
Hi!
Best,
Monika
