[Geoserver-users] (no subject)
Is it possible to apply different styles to different granules in an imagemosaic? I thought a simple sld filter using one of the attributes in the index shapefile might work, but it seems that only the image pixels are accessed. Is there any way to access the index shapefile from the sld? I have an imagemosaic with 5x multiband tiffs (predictions of a different habitat class, each with 11 bands representing a different quantile of prediction). I wish to create 11x different layers which will each access a particular band (prediction quantile), but the component tiffs need different styling. I’m trying to avoid having to publish 5x11 layers and an additional 5 layer groups.
This email is confidential, and is for the intended recipient only. Access, disclosure, copying, distribution, or reliance on any of it by anyone outside the intended recipient organisation is prohibited and may be a criminal offence. Please delete if obtained in error and email confirmation to the sender. The views expressed in this email are not necessarily the views of the University of Tasmania, unless clearly intended otherwise.
