[Geoserver-users] No WMS capabilities
I’m just learning Geoserver.
The WMS capabilities request did work when I first installed Geoserver. However, I did something (I’m not sure what!), as when I type in http://localhost:8080/geoserver/wms?request=getcapabilities, I get a:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
Translator error
A check of the Tocat log (stdout) gives this (partial) stacktrace:
9470031 [WARNING] org.vfny.geoserver.servlets.AbstractService - service exception while executing request: GetCapabilities [service: WMS, version: 1.1.1]
cause: Translator error
9470031 [SEVERE] org.vfny.geoserver.servlets.AbstractService - Service exception occurred
org.vfny.geoserver.wms.WmsException: Translator error
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabilitiesResponse.java:91)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:538)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:334)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:196)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:56)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframewo rk.web.servlet.mvc.SimpleControllerHandlerAdapter .handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalin a.core.ApplicationFilterChain.internalDoFilter(App licationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:833)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:639)
at org.apache.tomcat.util.net.AprEndpoint$ Worker.run(AprEndpoint.java:1285)
at java. lang.Thread.run(Unknown Source)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:104)
at org.vfny.geoserver.wms.responses.WMSCapabilitiesResponse.execute(WMSCapabilitiesResponse.java:89)
… 27 more
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleFeatureType(WMSCapsTransformer.java:773)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleFeaturesTree(WMSCapsTransformer.java:678)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.handleLayers(WMSCapsTransformer.java:476)
at org.vfny.geoserver.wms.responses.helpers.WMSCap sTransformer$CapabilitiesTranslator.handleCapability (WMSCapsTransformer.java:307)
at org.vfny.geoserver.wms.responses.helpers.WMSCapsTransformer$CapabilitiesTranslator.encode(WMSCapsTransformer.java:193)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:610)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:292)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:125)
… 29 more
I can still add files in Udig. Also a wfs and wcs capabilities request is fine. In addition, My mapbuilder viewer pulls in all the layers and renders them ok (albeit a bit slowly).
Any ideas?
Thank you.
What version of GeoServer are you using?
-Justin
jfulme1@anonymised.com wrote:
I'm just learning Geoserver.
However, I did something (I'm not sure what!), as when I type in
* * <!DOCTYPE ServiceExceptionReport/ (View Source for full doctype...)/>
*-* <file:///C:/Geography/Penn%20State/597F/Final_Project/wmscap.xml#>
<ServiceExceptionReport version="*1.1.1*">
* * <ServiceException>*Translator error*</ServiceException>
* * </ServiceExceptionReport>
version: 1.1.1]
exception occurred
at
at
at
at
at
at org.springf ramewo rk.web.servlet.mvc.SimpleControllerHandlerAdapter
at
at
at
at
at
at
at
at org.apache.c atalin
at
at
at
at
at
at
at
at
at
at org.apache.tomcat.util.net.AprEnd point$
at
at
at
... 27 more
at
at
at
at org.vfny.geoserver.wms.responses.helpers. WMSCap
at
at
at
at
at
... 29 more
Any ideas?
Thank you.
!DSPAM:1004,45f81840316941460912952!
opinions on IT & business topics through brief surveys-and earn cash
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
It's 1.5.0-RC1
Jim Fulmer
----- Original Message ----- From: "Justin Deoliveira" <jdeolive@anonymised.com>
To: <jfulme1@anonymised.com>
Cc: <geoserver-users@lists.sourceforge.net>
Sent: Wednesday, March 14, 2007 11:41 AM
Subject: Re: [Geoserver-users] No WMS capabilities
-Justin
The WMS capabilities request did work when I first installed Geoserver. However, I did something (I'm not sure what!), as when I type in
<SNIP>
Based on the stack trace it seems that something is wrong with the
style. My best guess is that the feature type references a style which
does not exist. Have you changed any of the styles attached to any of
the feature types?
-Justin
Jim wrote:
Hi Justin,
It's 1.5.0-RC1
Jim Fulmer
-Justin
<SNIP>
!DSPAM:1004,45f8691687301527717022!
Justin Deoliveira
