Hi List,
I am wondering if it is possible to use OAuth with 2.14.x along the lines of the current (2.18) documentation (https://docs.geoserver.org/stable/en/user/community/oauth2/index.html) and if so, where I can get the plugins alluded to in that documentation, for version 2.14.x. I have tried building 2.14.x branch from source but the repositories referenced in the pom.xml are outdated, and even when I fixed those issues as best I could it still failed some tests and I couldn’t get it to run.
Regards
Gus
On 03-09-2020 08:16, Gus MacAulay wrote:
Hi List,
I am wondering if it is possible to use OAuth with 2.14.x along the lines of the current (2.18) documentation (https://docs.geoserver.org/stable/en/user/community/oauth2/index.html) and if so, where I can get the plugins alluded to in that documentation, for version 2.14.x. I have tried building 2.14.x branch from source but the repositories referenced in the pom.xml are outdated, and even when I fixed those issues as best I could it still failed some tests and I couldn't get it to run.
The project moved the Maven repository to repo.osgeo.org so checking out the 14.x branch and changing the boundless repo to the osgeo repo should get you started, however the osgeo repo doesn't host GeoTools snapshots that old, so you'll also need to build GeoTools 20.x
Don't know about the tests, as 2.14.x is EOL basically you are on your own, but you could always build using "-DskipTests" to skip any tests
I'd upgrade to a supported release first though.
HTH, Mark
The project moved the Maven repository torepo.osgeo.org so checking out
As I suggested in my email, I was able to solve those problems enough to build.
Yes, but after that it didn't run
I have an active instance of 2.14 which I would like to maintain for a little longer if possible, hence my original question - are the oauth plugins available for 2.14?
HTH, Mark
Hopes dashed I'm afraid, but thanks for trying
Gus
These are community modules, hence unsupported… basically means you’d need to be able to support yourself even on an active GeoServer series
(all you get is some binaries built off the nightly builds, which may or may not work).
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
