I am implementing geoserver to run as a docker container. But geoserver fail to start due to unmappable characters. This error also occurs if I start geoserver with a new data_dir and try to save a style or workspace with a name with special character (åæø). This has not been an issue when geoserver has been deployed not using docker.
Does anyone have similar issues or found a way to solve it? I suppose the issue is how the image was built?
Caused by: java.nio.file.InvalidPathException: Malformed input or input contains unmappable characters: /opt/geoserver_data/workspaces/kpa_forslag/styles/KpBestemmelseOmr��de.xml.xml
Hi Kristian,
Checking the official docker image (2.23.2) I reproduced the same problem. Checking deeper into the container system I found the locale is configured as POSIX, hence only basic ASCII characters are allowed:
root@anonymised.com:/opt# locale
LANG=
LANGUAGE=
LC_CTYPE=“POSIX”
LC_NUMERIC=“POSIX”
LC_TIME=“POSIX”
LC_COLLATE=“POSIX”
LC_MONETARY=“POSIX”
LC_MESSAGES=“POSIX”
LC_PAPER=“POSIX”
LC_NAME=“POSIX”
LC_ADDRESS=“POSIX”
LC_TELEPHONE=“POSIX”
LC_MEASUREMENT=“POSIX”
LC_IDENTIFICATION=“POSIX”
LC_ALL=
I’ll open an issue to report this problem, meanwhile as workaround you can try this geoserver image which looks support UTF8 and special characters on workspace creation:
docker pull geosolutionsit/geoserver:2.23.2
docker run -it -p8080:8080 geosolutionsit/geoserver:2.23.2
Fernando Mino
Visit http://bit.ly/gs-services-us for more information.
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Fernando,
Thanks for checking and good to know that it looks to be something that can be fixed.
I have tried using the image you suggested before but have had some struggles to run it with plugins (probably due to my inexperience with docker).
(I already have a running task running with Alessandro cristofori at geosolutions already regarding that)
Fernando Mino
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
Med hilsen
Kristian Morin
Geodata, systemutvikling
Enhet for kart og arkitektur
Sentralbord: 72 54 25 00
Telefon: 90539229
Do you have a link to the reported issue? I tried to find it but I did not manage to find it.
I did however found a workaround to change locale during runtime that seem to be working by adding these environment attributes
-e LANG=C.UTF-8 -e LC_ALL=C.UTF-8
Fernando Mino
Fernando Mino
Software Engineer
@fmy2kec
GeoSolutions Group
Med hilsen
Kristian Morin
Telefon: 90539229
Med hilsen
Kristian Morin
Telefon: 90539229
