[Geoserver-users] OpenLayers GetFeatureInfo Error in Geoserver
Hi
I'm building an openlayers map to be served up by GeoServer my layers
consist of a Postgis Base layer and one or many other postgis vector layers
created using SQL viewparams from the same PostGis table and a on the fly
vector layer.
If i have one viewparams layer when i click on the map i can display the
attribution of that layer.
How ever if i add more than one viewparams layers an error similar to 3
layers selected but 2 veiwparams occurs when you click on the map.
Is it possible to do this?
My openlayers code is generated from a perl script the code below is the
result of right click View Page Source.
<html xmlns="http://www.w3.org/1999/xhtml&quot;&gt;
  <head>
        <link rel="stylesheet"
type="text/css"href="http://localhost:8080/geoserver/openlayers/theme/default/style.css&quot;/&gt;
        <link rel="stylesheet" type="text/css"
href="http://localhost:8080/geoserver/www/scale/scalebar-fat.css&quot;/&gt;
        </style>
  </head>
  <body onload="init()">
OpenLayers PostGis Layers
    <DIV id=layerswitcher class=olControlLayerSwitcher></DIV>
    <div id="map"></div>
        <div id="wrapper">
        <div id="location">location</div>
        <div id="scale"> </div>
        <div id=scalebar></div>
    </div>
    <div id="nodelist">
    </div>
  </body>
</html>
View this message in context: http://osgeo-org.1560.n6.nabble.com/OpenLayers-GetFeatureInfo-Error-in-Geoserver-tp4917494p4917494.html
