Hi Ben,
Yes, the original SQL error has gone away. However, it might be because of more immediate errors.
When I use GeoServer 2.1 beta 3, my configuration seems to give the desired results.
The query
http://localhost:8080/geoserver21b3/kms/wfs?version=1.1.0&service=WFS&request=GetFeature&typename=kms:Jordstykke&maxfeatures=4&filter=<Filter%20xmlns="http://www.opengis.net/ogc"><PropertyIsEqualTo><PropertyName>kms:featureID</PropertyName><Literal>1613974</Literal></PropertyIsEqualTo></Filter>
yields a response with data in GML, and the following is in the log:
2011-02-16 13:17:35,337 INFO [geoserver.wfs] -
Request: getFeature
handle = null
service = WFS
version = 1.1.0
baseUrl = http://localhost:8080/geoserver21b3/
providedVersion = null
extendedProperties = {}
query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: [ kms:featureID = 1613974 ], sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://schemas.kms.dk/wfs\}Jordstykke])]
maxFeatures = 4
outputFormat = text/xml; subtype=gml/3.1.1
resultType = results
traverseXlinkDepth = null
traverseXlinkExpiry = null
formatOptions = {}
metadata = null
I then use the same workspace configuration in GeoServer 2.1 RC 1, and the query results in an error that puts the below entries in the log.
I had expected that I would have been able to simply copy a configuration from beta 3 to RC 1.
Kind regards,
Morten
2011-02-16 12:53:05,476 DEBUG [geoserver.requests] - Query is net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: , propertyName: , function: null, filter: [ kms:featureID = 1613974 ], sortBy: , featureVersion: null, handle: null, srsName: null, typeName: [{http://schemas.kms.dk/wfs\}Jordstykke])
To gt2: Query:
feature type: Jordstykke
[properties: ALL ]
2011-02-16 12:53:05,476 DEBUG [geotools.jdbc] - CREATE CONNECTION
2011-02-16 12:53:05,476 TRACE [geotools.core] - ENTRY 14
2011-02-16 12:53:05,476 DEBUG [geotools.filter] - exporting SQL ComparisonFilter
2011-02-16 12:53:05,476 DEBUG [geotools.filter] - exporting PropertyName
2011-02-16 12:53:05,476 DEBUG [geotools.jdbc] - SELECT KFID,UUID,FEATUREID,FEATURETYPE,FEATURECODE,DATASETIDENTIFIER,DATAQUALITYSPECIFICATION,DATAQUALITYSTATEMENT,DATAQUALITYDESCRIPTION,DATAQUALITYPROCESSOR,DATAQUALITYRESPONSIBLEPARTY,TIMEOFCREATION,TIMEOFPUBLICATION,TIMEOFREVISION,ESR_EJENDOMSNUMMER,KMS_SAGSID,KMS_JOURNALNUMMER,REGISTRERINGSDATO,EJERLAVSNAVN,LANDSEJERLAVSKODE,MATRIKELNUMMER,FAELLESLOD,MODERJORDSTYKKE,SUPMSAGSID,SKELFORRETNINGSSAGSID,REGISTRERETAREAL,AREALBEREGN,VEJAREAL,VEJAREALBEREGN,VANDAREALBEREGN,AREALTYPE,REGIONSKODE,REGIONSNAVN,KOMMUNEKODE,KOMMUNENAVN,SOGNEKODE,SOGNENAVN,RETSKREDSKODE,RETSKREDSNAVN,SURFACEPROPERTY as SURFACEPROPERTY FROM LDS_2.KF_JORDSTYKKE_V WHERE FEATUREID = ?
2011-02-16 12:53:05,476 DEBUG [geotools.jdbc] - 1 = 1613974
2011-02-16 12:53:05,617 DEBUG [geotools.jdbc] - CREATE CONNECTION
2011-02-16 12:53:05,695 TRACE [geotools.core] - ENTRY -12.345
2011-02-16 12:53:05,695 DEBUG [geotools.jdbc] - SELECT KFID,UUID,FEATUREID,FEATURETYPE,FEATURECODE,DATASETIDENTIFIER,DATAQUALITYSPECIFICATION,DATAQUALITYSTATEMENT,DATAQUALITYDESCRIPTION,DATAQUALITYPROCESSOR,DATAQUALITYRESPONSIBLEPARTY,TIMEOFCREATION,TIMEOFPUBLICATION,TIMEOFREVISION,ESR_EJENDOMSNUMMER,KMS_SAGSID,KMS_JOURNALNUMMER,REGISTRERINGSDATO,EJERLAVSNAVN,LANDSEJERLAVSKODE,MATRIKELNUMMER,FAELLESLOD,MODERJORDSTYKKE,SUPMSAGSID,SKELFORRETNINGSSAGSID,REGISTRERETAREAL,AREALBEREGN,VEJAREAL,VEJAREALBEREGN,VANDAREALBEREGN,AREALTYPE,REGIONSKODE,REGIONSNAVN,KOMMUNEKODE,KOMMUNENAVN,SOGNEKODE,SOGNENAVN,RETSKREDSKODE,RETSKREDSNAVN,SURFACEPROPERTY as SURFACEPROPERTY FROM LDS_2.KF_JORDSTYKKE_V WHERE 0 = 1
2011-02-16 12:53:05,710 WARN [data.complex] - This shouldn't have happened.There should be at least 1 features with id='KF_JORDSTYKKE_V.fid-58777fea_12e2decb235_-7fdf'.
2011-02-16 12:53:05,710 DEBUG [geotools.jdbc] - CLOSE CONNECTION
2011-02-16 12:53:05,710 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error applying mapping with targetAttribute kms:featureID
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:739)
at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:171)
at org.geotools.data.complex.MappingFeatureCollection.size(MappingFeatureCollection.java:300)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:372)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:114)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy95.getFeature(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.RangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:736)
... 155 more
-----Oprindelig meddelelse-----
Fra: Ben Caradoc-Davies [mailto:Ben.Caradoc-Davies@anonymised.com]
Sendt: 15. februar 2011 03:51
Til: Lindegaard, Morten
Emne: Re: SV: [ExternalEmail] Re: [Geoserver-users] ORA-01427 in RC1, app-schema
[I'm putting this discussion back on the list where it belongs. There
are a lot more on the list who might be able to help.]
Morten,
turning on VERBOSE_LOGGING should show you all SQL statements. They
should be on lines containing "[geotools.jdbc]". You might have to
reload the GeoServer servlet (logging can be a bit twitchy). It looks
like your SQL error has gone away.
Rini thinks you should be seeing more in your error messages (see
below). Niels added these diagnostics so might be able to help.
Kind regards,
Ben.
-------- Original Message --------
Subject: RE: SV: [ExternalEmail] Re: [Geoserver-users] ORA-01427 in RC1,
app-schema
Date: Tue, 15 Feb 2011 10:36:54 +0800
From: Angreani, Rini (CESRE, Kensington) <Rini.Angreani@anonymised.com>
Hmm, the error is there to isolate the problem to an attribute mapping.
It was done for catching invalid attribute mapping, e.g. if the column
it's mapped to doesn't exist.
But, it should have the original exception printed as well, e.g.
something like:
gml:name[4]
Error applying mapping with targetAttribute gml:name[4]
Could not find working property accessor for attribute (DESCRIPTIO) in
object
(SimpleFeatureImpl:InvalidColumnGeologicUnit=[SimpleFeatureImpl.Attribute:
NAME&lt;NAME id=gu.93&gt;=Yaugher Volcanic Group,
SimpleFeatureImpl.Attribute: CODE&lt;CODE id=gu.93&gt;=-Py,
SimpleFeatureImpl.Attribute: URN&lt;URN
id=gu.93&gt;=urn:x-test:GeologicUnit:16777549126931093,
SimpleFeatureImpl.Attribute: DESCRIPTION&lt;DESCRIPTION
id=gu.93&gt;=Olivine basalt, tuff, microgabbro, minor sedimentary
rocks])
No value for xpath: DESCRIPTIO
So, without the full stack trace, it's hard to determine the cause.
On 14/02/11 18:21, Lindegaard, Morten wrote:
Hi Ben,
Thank you for the suggestions!
I used verbose logging, but I didn't find the SQL. I'll take a closer look at the view.
I have attached a zip-file containing the workspace with my mapping files.
However, I'm unable to reproduce the ORA-01427 error at the moment. So I'm afraid it is no help. Since I tried various things to fix the error, I have most likely changed something in the mapping files and forgotten about it.
Right now, I run into this error:
java.lang.RuntimeException: Error applying mapping with targetAttribute kms:harSamletFastEjendom
Error applying mapping with targetAttribute FEATURE_LINK
Index: 0, Size: 0
So that's what I'm trying to get around now...
If there is anything in my mapping files that looks suspicious at a glance, I'll be happy to know.
Kind regards,
Morten
Miljøministeriet, Kort& Matrikelstyrelsen, direkte tlf. 72545506. Officiel kommunikation bedes dirigeret via e-mail kms@anonymised.com eller telefon 72545000
Sendt: 11. februar 2011 05:56
Emne: Re: [ExternalEmail] Re: [Geoserver-users] ORA-01427 in RC1, app-schema
Morten, here are some suggestions from a colleague:
On 11/02/11 11:21, Warren, Peter (CESRE, North Ryde) wrote:
> Does Geoserver build SQL with subqueries? I wouldn't have thought
so. If it doesn't then this is likely an error in a view definition.
> If it does build SQL with subqueries then this could be caused by
duplicate feature_IDs used in the chaining.
> Note: We really don't have much to go on here so I could be wrong.
On 11/02/11 10:30, Ben Caradoc-Davies wrote:
Morten,
please turn on verbose logging and let us know if you can see the SQL
that is generated when you get this error.
Can we please see your app-schema mapping file?
Kind regards,
Ben.
On 10/02/11 20:22, Lindegaard, Morten wrote:
I have installed 2.1-RC1 recently, and I have copied a configuration that use the app-schema and oracle extensions from beta3 to RC1.
The configuration nests features, and selects from various views and tables.
It works fine in beta3, but RC1 fails with "java.lang.RuntimeException: java.sql.SQLException: ORA-01427: single-row subquery returns more than one row".
Does anyone know of changes from beta3 to RC1 that would explain the change in behaviour?
Thanks in advance!
Kind regards,
Morten Lindegaard
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
