my GS 1.7.7 is unable to create a connection with Oracle. It was
running fine untill I tried to create a new database with OCI but OCI
driver was not installed. So I tried to create the datastore using
simple jdbc driver and now it just wont connect, the blue mark appears
saysing Connection Test failed. Could geoserver still be looking for
that OCI driver? or Do I need to copy the jars again?
14 May 10:59:05 WARN [geoserver.action] - Unable to fetch a list of
FeatureType names from datastore.
org.geotools.data.DataSourceException: Connection test failed
at org.geotools.data.jdbc.datasource.DataSourceUtil.buildDefaultDataSource(DataSourceUtil.java:123)
at org.geotools.data.oracle.OracleDataStoreFactory.getDefaultDataSource(OracleDataStoreFactory.java:198)
at org.geotools.data.oracle.OracleDataStoreFactory.createDataStore(OracleDataStoreFactory.java:183)
at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:75)
at org.vfny.geoserver.util.DataStoreUtils.acquireDataStore(DataStoreUtils.java:59)
at org.vfny.geoserver.action.data.DataDataStoresEditorAction.execute(DataDataStoresEditorAction.java:147)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:227)
at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:125)
at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:292)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:26)
at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:56)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
I.R
regards.
