[Geoserver-users] ORACLE doesnt recogize GEOMETRY column [Sec=Unclassified]
Choe,
> From: geoserver-users-bounces@lists.sourceforge.net
> [mailto:geoserver-users-bounces@lists.sourceforge.net] On
> Behalf Of Choe
> Sent: Thursday, 13 December 2007 2:54 AM
> The GEOMETRY COLUMN has a type MDSYS.SDO_GEOMETRY in oracle
> spatial and was inserted from a shape file.
Did you try previewing the table from the demo page to see if it worked
anyway?
If it doesn't work, check that you have:
A) A primary key
B) A valid spatial metadata entry
C) A spatial index
D) Appropriate access privileges to the table and spatial metadata
E) Valid data in your table
Miles
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.antarctica.gov.au/
