Hi ,
I've a problem with oracle and geoserver.
I've a table Oracle with World map data epsg:4326 (this table has been loaded with shp2sdo.exe and I've do everything the tutorial said correctly)
, then I load datas in geoserver, that works good then I displays this data in Mapbuilder that works too.
But when I want to display this data with a mercator projection, reprojection failed .
Reprojection works for every epsg to epsg;4326 but not for every epsg to mercator_1SP epsg (as google map);
I believe that it was because I specify epsg:4326 in Oracle table but if I specify "null" or others for the SRID, that doesn't worked too.
These reprojections I try to make, works very good with shapefile datastore or postgis datastore so it can't be a mapbuilder issue.
I precise that I call reprojection a GetMap request to geoserver with an epsg who uses mercator_1SP.
So my question is :
Do you think it's a geoserver problem or an oracle problem?
Do you think it's because geom datas in the table are in lat/long?
and if anybody has resolved this problem, please answer me?
I use
Oracle 10g express edition
Geoserver 1.4 RC3
Mapbuilder trunk
olivier.terral ha scritto:
Hi ,
So my question is :
Hmm... Oracle datastore is a can of worms, and nobody seems to have the
time to fix it. Yet, with no stack traces it's hard to tell what's going
on... It may be even data dependent. Can you give us more info?
Thanks andre to answer me
In fact, geoserver seems to loads data correctly so I've no log to show you
Problem, it's when I make a GetMap request, all datas doesn't displayed.
For example with basic data world (epsg 4326 & bounding box =-180;-90;9,180)
sometimes only antartic and asia are displayed
sometimes only europe and africa are displayed.
But I' m sure datas are loded coorectly because when I zoom anywhere in the
map ( and so I reduce bbox) all datas in the new bbox are displayed
correctly.
Do you think geoserver it's limited to load a certain number of polygon ?
Please help me I become crazy
Hi ,
correctly)
So my question is :
Join SourceForge.net's Techsay panel and you'll get the chance to share
your
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
View this message in context: http://www.nabble.com/oracle-mercator-projection-tf2766770.html#a7741093
sometimes only antartic and asia are displayed sometimes only europe and africa are displayed.
correctly.
It is by default, but the number of polygons is very high (1000000 or so), so it should not be your case. Do you have any stack trace or the like? Have you tried increasing logging level and see if you can find
more info? Can you send me the data you're using?
Ciao Andrea,
After investigations, it seems to be a Java heap space problem that generate a strange behavior.
will have a look at it tomorow.
Cheers.
Vincent Heurteaux
Société Geomatys
vincent.heurteaux@anonymised.com
http://www.geomatys.fr
In fact, geoserver seems to loads data correctly so I’ve no log to show you
Problem, it’s when I make a GetMap request, all datas doesn’t displayed.
But I’ m sure datas are loded coorectly because when I zoom anywhere in the
correctly.
Do you think geoserver it’s limited to load a certain number of polygon ?
more info? Can you send me the data you’re using?
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
Vincent Heurteaux ha scritto:
Ciao Andrea,
Ah, bigger area, more data to handle... yet, it's somewhat funny, since
the streaming renderer is specifically designed for low memory consumption. Keep me posted, I'm curious.
Andrea,
I think we’ve identifyed the problem.
We’re using the thrunk with gt 2.3.1 because we need WCS and our NetCDF plug-in. In this case we encourter problems when displaying the layers form Oracle (express edition).
We’ve tested Geoserver 1.4.0-RC4, and everything goes fine, so I suspect changes in gt 2.3 jars used by Oracle plug-in
Have you got any clue ?
I join screenshots from 1.4.0-RC4 and 1.5.0-BETA1
(Attachment World_1.4.0-RC4.png is missing)
(Attachment World_1.5.0_BETA1.png is missing)
Andrea,
I think we've identifyed the problem.
We're using the thrunk with gt 2.3.1 because we need WCS and our NetCDF plug-in. In this case we encourter problems when displaying the layers form Oracle (express edition).
We've tested Geoserver 1.4.0-RC4, and everything goes fine, so I suspect changes in gt 2.3 jars used by Oracle plug-in
Unfortunately not. Are you sure the log, eventually set at fine or finer levels, do not give you any extra information?
Andrea,
Sorry I haven't seen this part of logs
I find an error it seems on the StreamingRenderer (with the geotools version 2.3.1).
[INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
java.util.logging.ErrorManager: 5
java.lang.NullPointerException
at java.io.Writer.write(Unknown Source)
at org.vfny.geoserver.global.Log4JFormatter.format(Log4JFormatter.java:158)
at java.util.logging.StreamHandler.publish(Unknown Source)
at org.vfny.geoserver.global.Log4JFormatter$Stdout.publish(Log4JFormatter.java:366)
at java.util.logging.Logger.log(Unknown Source)
at java.util.logging.Logger.doLog(Unknown Source)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:1626)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:1530)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1472)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:687)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:430)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:269)
at org.vfny.geoserver.wms.responses.GetMapResponse.execute(GetMapResponse.java:308)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:195)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:58)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:252)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:173)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:202)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:178)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:126)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:105)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:107)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:148)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:869)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:664)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:527)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:80)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:684)
at java.lang.Thread.run(Unknown Source)
