All images are the same as far as type. They are land images where in each directory they line up next to each other from east to west. They should all have the same characteristics for the most part.
I got them from here: http://data.labins.org/2003/MappingData/DOQQ/doqq_04_utm_sid.cfm
From: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] On Behalf Of Daniele Romagnoli
Sent: Friday, May 15, 2009 12:22 PM
To: Robert Webb
Cc: Joshua M. Thompson; geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] [OT] New user needs general help
Hi Robert,
can you give us some additional information about the images are you mosaicking?
Do they share some similarities or are you trying to mosaic totally different images? (as an instance: different types, different overviews characteristics, totally different resolution,..)
Let us know.
Daniele
On Fri, May 15, 2009 at 5:57 PM, Robert Webb <rwebb@anonymised.com<mailto:rwebb@anonymised.com>> wrote:
-----Original Message-----
From: Joshua M. Thompson [mailto:joshua.thompson@anonymised.com]
Sent: Friday, May 15, 2009 10:51 AM
To: geoserver-users@lists.sourceforge.net<mailto:geoserver-users@anonymised.comurceforge.net>
On Fri, May 15, 2009 at 8:24 AM, Robert Webb <rwebb@anonymised.com<mailto:rwebb@anonymised.com>> wrote:
> Ok, still not working. Tried the URL as "file:/opt/tomcat-
6.0/webapps/geoserver/data/data/jpeg2000/g05/" and "file:
data/data/jpeg2000/g05/".
Shouldn't that be
"file:///opt/tomcat-6.0/webapps/geoserver/data/data/jpeg2000/g05/"?
That's the technically correct format for a file: URL. and it's how I
set up the paths to a bunch of my coverage stores.
Tried your suggestion and I did get the coverage and coverage store setup. However, when I click on the coverage from the demo I do not get anything displayed. Just the bounding box and controls.
I do see seven new files created in the directory. All of them start with g05-sids (which is the directory name) and have the extensions of dbf, fix, prj, properties, qix, shp, shx.
I am seeing the following on the Catalina.out log:
May 15, 2009 11:52:52 AM it.geosolutions.imageio.gdalframework.GDALImageReader readDatasetRaster
INFO: Last error: IReadBlock failed at X offset 6, Y offset 6
INFO: Last error number: 1
INFO: Last error type: 3
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables
unlimited royalty-free distribution of the report engine
for externally facing server and web deployment.
http://p.sf.net/sfu/businessobjects
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrge.net>
Eng. Daniele Romagnoli
Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 328 0559267
