Dear List,
Currently we‘re facing problems with the output formats for the GetFeature request.
For all our services we have double entries in our capabilities for application\geo+json (this applies to version 2.0.0 and 1.1.0).
For the format application\stac+json we’re always getting the following error message:
Failed to find response for output format application\stac+json
Here are some example requests:
https://sgx.geodatenzentrum.de/wfs_vg5000_1231?service=wfs&version=1.1.0&request=GetCapabilities
https://sgx.geodatenzentrum.de/wfs_vg5000_1231?service=wfs&version=1.1.0&request=GetFeature&TYPENAME=vg5000_krs&BBOX=684300,5700200,684500,5700400,EPSG:25832&OUTPUTFORMAT=application%2Fstac%2Bjson
We are currently running on Geoserver 2.22.2
Is this a known issue? Has somebody a solution or a workaround for those problems?
Kind regards,
Anna-Lena Hock
HI Anna,
if you have that stac+json output format, then I’m betting you’re using a community module, the OGC-API one maybe?
That’s what’s adding that output format, which happens to only work with the OGC API itself.
Community modules tend to be experimental and can provide some exciting new features along with some level
of discomfort/instability. In your case the solution should be easy though… go into WEB-INF/lib and remove the
jar responsible for “OGC API - Images”, should be gs-ogcapi-images-.jar.
Restart, and that output format should be gone
Best regards
Andrea Aime
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hi andrea,
Thanks for the fast reply! It was the solution to both problems. We had to remove all ogc api jars, but then the problems in the capabilities disappeared.
I understand that the ogc-api features are a community module.
Is it planned to solve the problem with the capabilities? Would it help to report a bug? Of course we would like to offer the ogc-api features sooner or later - so when will it be possible to use a stable version of the extension? Is there already enough funding for it?
Best regards,
Anna
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Anna,
the OGC API module packaging changed on the development branch and
now the services are separated. For example, on this server ew only have a subset of all possible OGC APIs, which does not include OGC API - images:
https://gs-main.geosolutionsgroup.com/geoserver/web
If you try out the WFS capabilities document, you should see there is no trace of the STAC JSON flavour.
So, the issue you found should have been fixed already (but only in the development branch, mind, which
will become stable in September).
Best regards
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
