Hi list,
is it possible to override projection parameters of an existing projection
(already present in the HSQL database). It looks like the one from the HSQL
database prevails over the one in the properties file. Or am I missing
something?
Using 1.5.3.
Best regards,
Bart
Bart van den Eijnden
OSGIS, Open Source GIS
http://www.osgis.nl
On 10/19/07, Bart van den Eijnden (OSGIS) <bartvde@anonymised.com> wrote:
Hi list,
something?
You can simply use a different EPSG code in your properties file, and
then use that. Both definitions (the one in the HSQL database and
yours) should coexist happily.
Alex
