[Geoserver-users] Passing BBOX to an SQL View
Hello All,
Is there a way to pass the current bounding box to your database engine with Geoserver when using an SQL view? I am using PostgreSQL in this case.
I know I can set parameters which I can then use, but as this information is already available I was hoping there was some way of accessing it directly. Essentially I want the same value as I’d get using the wms_bbox option from a SLD for use in the SQL View.
My impression is this might not be possible at the moment.
James Sewell,
PostgreSQL Team Lead / Solutions Architect
Level 2, 50 Queen St, Melbourne VIC 3000
P (+61) 3 8370 8000 W www.lisasoft.com F (+61) 3 8370 8099
Hi James,
the short answer is no, if you are up to read a 44 messages thread, this topic
has been beaten to death (with no subsequent action) on this mailing list,
search for “Reducing query data size in Oracle” in the last few months archives
On Mon, May 18, 2015 at 8:10 AM, James Sewell <james.sewell@anonymised.com> wrote:
Hello All,
James Sewell,
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
