[Geoserver-users] Performance on GetLegendGraphic
We are experiencing quite drastic differences in performance when requesting legend graphics (request=GetLegendGraphic) on WMS services running on different GeoServer installations.
In one case each request uses around 20 ms and in another similar requests use 800-1000 ms.
The general performance of the two servers is quite similar.
Any hints on what determines the processing time on such requests?
Best regards,
Morten Storm
Chefkonsulent
GetLegendGraphic in general should be quick, as it just has to inspect the style and render the data.
However, there are parameters that make it access data, they are the ones to count features matched, and
eliminate rules that are not on the current map… in that case, it would definitely take more time.
Hard to say more, you’re not giving us much context… GeoServer version, the legend graphic request, the styles, and so on…
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Sorry for the sparse context description – and my delayed response.
I have now made a comparison using the same style (albeit on two different polygon layers) on two different servers both running GeoServer v. 2.14.5.
Specs for server I:
  • Intel Xeon Gold 6234 (1 socket, 4 virtual processors)
  • 24 GB RAM
Specs for server II:
  • Intel Xeon Silver 4208 (2 sockets, 4 virtual processors)
  • 32 GB RAM
I have setup layers with the following (simple) style on both servers:
sld:NamedLayer
sld:NamePolygon_style</sld:Name>
sld:UserStyle
sld:TitlePolygon style</sld:Title>
sld:FeatureTypeStyle
sld:Namename</sld:Name>
sld:Rule
sld:Name7_BYGNDIV</sld:Name>
sld:Title7_BYGNDIV</sld:Title>
sld:MaxScaleDenominator2000</sld:MaxScaleDenominator>
sld:PolygonSymbolizer
sld:Fill
sld:GraphicFill
sld:Graphic
sld:Mark
sld:WellKnownNameshape://backslash</sld:WellKnownName>
sld:Fill
<sld:CssParameter name=“fill”>#6E6E6E</sld:CssParameter>
</sld:Fill>
sld:Stroke
<sld:CssParameter name=“stroke”>#6E6E6E</sld:CssParameter>
</sld:Stroke>
</sld:Mark>
sld:Size10</sld:Size>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
sld:Stroke
<sld:CssParameter name=“stroke”>#FF0000</sld:CssParameter>
</sld:Stroke>
</sld:PolygonSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
The request is
https:///Server/MapServiceProxy?mapServiceId=eca7ca5c-f0fe-45d8-a279-747eb9bfbae6&service=WMS&version=1.1.1&request=GetLegendGraphic&FORMAT=image/png&transparent=true&layer=Forsyning:Polygon
The response time for this request is:
On server I: 17-23 ms
On server II: 904-962 ms
Any hints on what causes this huge difference in response time?? The same difference is seen generally on all GetLegendGraphic requests, causing server I to load the webpage very much faster than server II…
Best regards,
Morten Storm
Fra: Andrea Aime <andrea.aime@…10949…>
Sendt: 6. september 2021 15:53
Til: Morten Storm <ms@…8610…>
Emne: Re: [Geoserver-users] Performance on GetLegendGraphic
On Mon, Sep 6, 2021 at 3:02 PM Morten Storm via Geoserver-users <geoserver-users@lists.sourceforge.net> wrote:
Best regards,
Morten Storm
Chefkonsulent
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
The style is pretty much self contained, so should be pretty quick to render. The GeoServer version is the same… would seem to suggest the difference is somewhere else.
Did you check the proxying thing you have going on? This URL is not coming from a straight GeoServer call, it even says “proxy” in it:
Try making direct requests to GeoServer, without going through that proxy and possible authentication, is the timing still different?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
