My bad, I have given you a truncated gdalinfo. This is it:
Driver: JP2MrSID/MrSID JPEG2000
Files: E:\geoserver_data_dir\coverages\orto_navarra_2012\navarra2012_ortofoto25c
m_etrs89.jp2
m_etrs89.j2w
Size is 598240, 638720
Coordinate System is:
PROJCS[“ETRS89 / UTM zone 30N”,
GEOGCS[“ETRS89”,
DATUM[“European_Terrestrial_Reference_System_1989”,
SPHEROID[“GRS 1980”,6378137,298.2572221010002,
AUTHORITY[“EPSG”,“7019”]],
AUTHORITY[“EPSG”,“6258”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4258”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-3],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,0],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“25830”]]
Origin = (539240.000000000000000,4798780.000000000000000)
Pixel Size = (0.250000000000000,-0.250000000000000)
Metadata:
GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
GEOTIFF_NUM__1026__GTCitationGeoKey=This file was created with the ECW JPEG 20
00 SDK build 4.2.0.64 copyright 1998-2005 by ER Mapper. This GeoJP2 header was
translated from the following ER Mapper style registration information:
fOriginX: 539240.000000
fOriginY: 4798780.000000
fCellIncrementX: 0.250000
fCellIncrementY: -0.250000
fCWRotationDegrees: 0.000000
szProjection: EPSG:25830
szDatum: EPSG:25830
GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=25830
GEOTIFF_CHAR__ProjectedCSTypeGeoKey=Unknown-25830
GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9001
GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Meter
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 539240.000, 4798780.000)
Lower Left ( 539240.000, 4639100.000)
Upper Right ( 688800.000, 4798780.000)
Lower Right ( 688800.000, 4639100.000)
Center ( 614020.000, 4718940.000)
Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
Minimum=11.000, Maximum=255.000, Mean=177.955, StdDev=81.483
Overviews: 299120x319360, 149560x159680, 74780x79840, 37390x39920, 18695x19960
, 9348x9980, 4674x4990, 2337x2495, 1169x1248, 585x624, 293x312, 147x156, 74x78,
37x39
Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
Minimum=18.000, Maximum=255.000, Mean=178.914, StdDev=79.212
37x39
Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
Minimum=8.000, Maximum=255.000, Mean=172.125, StdDev=85.485
37x39
De: Fernando Lacunza Prieto [mailto:flacunza@anonymised.com]
Enviado el: miércoles, 03 de abril de 2013 11:51
Para: Daniele Romagnoli
CC: geoserver-users@lists.sourceforge.net
Asunto: Re: [Geoserver-users] Performance with huge JPEG2000
Ciao Daniele,
The gdalinfo from the file is below:
GEOGCS[“ETRS89”,
UNIT[“metre”,1,
Metadata:
szDatum: EPSG:25830
INTERLEAVE=PIXEL
Corner Coordinates:
37x39
37x39
37x39
The layer is EPSG:25830 at both native and declared SRS. To ensure there is no reprojection the SRS handling is set to “force declared”.
At the coverage parameters I had initially SUGGESTED_TILE_SIZE=512,512, USE_JAI_IMAGEREAD=true, USE_MULTITHREADING=false, but I have switched the last two parameters to USE_JAI_IMAGEREAD=false, USE_MULTITHREADING=true and I have experimented an increase in performance: now I have 16 to 18 seconds per map request, but no later downtime from GeoServer.
The tile caching is as default, enabled for EPSG:900913 and EPSG:4326, but this option is not triggered as I am trying to build the cache in EPSG:25830. I don’t see any need to use tile caching in this case, since the sole purpose of the WMS is to serve MapProxy so it can build the WMTS cache.
Best regards,
Fernando Lacunza
De: dany.geotools@anonymised.com [mailto:dany.geotools@anonymised.com] En nombre de Daniele Romagnoli
Enviado el: martes, 02 de abril de 2013 15:33
Para: Fernando Lacunza Prieto
can you run a gdalinfo on your file or provide us some more info on the inner structure of that file (progression order, tiling, decomposition levels, …)?
Moreover, how did you configure the layer on geoserver?
Please, let us know.
Daniele
On Tue, Apr 2, 2013 at 2:26 PM, Fernando Lacunza Prieto <flacunza@anonymised.com..5224…> wrote:
Hello everyone,
I have a really big JPEG2000 file (598240x638720 pixels, about 54 GB) published in a WMS by GeoServer 2.2 and the GDAL extension. The file is accessed with a JP2MrSID store. The purpose of that WMS is to serve tiles to MapProxy to build a WMTS cache.
Unfortunately, the performance is appalling: each GetMap request lasts 10 to 15 seconds, and after that GeoServer stops responding for another 15 to 20 seconds. At this rate, my WMTS cache would be done in about 5 years, and I do not want to wait so long.
¿Is there some tweaking I can do to increase the performance to acceptable levels? I am a newbie in both GeoServer and MapProxy, and I fear that my approach to the problem could be wrong. Therefore, any suggestions to accomplish the task of building a restful WMTS cache from a JPEG2000 file are welcome.
Thanks!
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
Own the Future-Intel(R) Level Up Game Demo Contest 2013
Rise to greatness in Intel’s independent game demo contest. Compete
for recognition, cash, and the chance to get your game on Steam.
$5K grand prize plus 10 genre and skill prizes. Submit your demo
by 6/6/13. http://altfarm.mediaplex.com/ad/ck/12124-176961-30367-2
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
