hello peoples, i need help, i got a problem, i need to auntenticate throught php in geoserver, in the past with the version geoserver 2.1.4 it work fine, but now i want to upgrade my map server to geoserver 2.2 and the function dont work here, i dont know what to do, help me please, here is the full function that i used and error that geoserver 2.2 show, thanks to all.
public static function loginGeoserver($username, $password)
$post_data['username'] = $username;
$post_data['password'] = $password;
foreach ($post_data as $key => $value) {
$post_items = $key . '=' . $value;
$post_string = implode('&', $post_items);
$curl_connection = curl_init('http://' . master::$host .
'/geoserver/j_spring_security_check');
curl_setopt($curl_connection, CURLOPT_CONNECTTIMEOUT, 30);
curl_setopt($curl_connection, CURLOPT_USERAGENT,
"Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1)");
curl_setopt($curl_connection, CURLOPT_RETURNTRANSFER, true);
curl_setopt($curl_connection, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl_connection, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($curl_connection, CURLOPT_POSTFIELDS, $post_string);
$result = curl_exec($curl_connection);
$arrInfo = curl_getinfo($curl_connection);
$url = $arrInfo['url'];
parse_str($url, $output);
$trans = array("." => "_");
$base = strtr(master::$host, $trans);
if (master::getLoggedUser() != null) {
if (master::getLoggedUser()->tieneRol("Operador"))
$str = "http://" . $base . "/geoserver/web/;jsessionid";
$str = "http://" . $base . "/geoserver/;jsessionid";
curl_close($curl_connection);
if (!empty($output[$str])) {
} else {
//header('Location: /geoportal/index.php?page=home.home&Error=GeoserverDown');
header('Location: /personal/index.php?page=inicio&Error=GeoserverDown');
setcookie('JSESSIONID', $output[$str], 0, '/geoserver');
setcookie('JSESSIONID', $output[$str], 0, '/');
} else {
return null;
and the geoserver 2.2 logs show this
2013-05-17 22:37:48,863 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler 'dispatcher'
2013-05-17 22:37:49,861 WARN [geoserver.security] - E:\geoserver-2.2-RC1-bin\data_dir\security\users.properties.old could be removed manually
2013-05-17 22:46:23,167 INFO [geoserver.filters] - Creating a new http session outside of the web UI! (normally not desirable), the path is/j_spring_security_check
java.lang.Exception: Full stack trace for the session creation path
at org.geoserver.filters.SessionDebugFilter$SessionDebugWrapper.getSession(SessionDebugFilter.java:93)
at javax.servlet.http.HttpServletRequestWrapper.getSession(HttpServletRequestWrapper.java:227)
at org.springframework.security.web.context.HttpSessionSecurityContextRepository$SaveToSessionResponseWrapper.createNewSessionIfAllowed(HttpSessionSecurityContextRepository.java:339)
at
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
